House power for 2.66 GHz Celeron
  • House power for 2.66 GHz Celeron
    Check my sig for system specs.
    With my older machines (much lower GHz, same Keypower PS), I was able to use junk power supplies to power the machine in my house (wire from yellow on the house ps to +12 on Keypower).
    On this new machine, that method doesn't seem to work. Everything blinks on for a second then everything shuts off. I'm using the ATX jumper trick on the household power supply, so I unplug it momentarily, and nothing. Wait 2 minutes, plug in, blink on then nothing. (internal fuse blows, I guess)
    I've tried this with 3 power supplies. When I plug each one into the mobo and other devices in the carputer, they all work fine.
    So, what's happening?
    My slightly educated guess is that the yellow wire I connect to on the house ps is connected to one +12v rail, which isn't enough.
    So, how to fix this?
    Is there a way I can bridge rails? How can I tell which yellow wires connect to +12v rails? And could the problem lie in trying to force that much power through tiny 14 guage wires comming out of the ps? Should I spend $$$(!) on a dedicated (high-amp) 120V to 12V converter?
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
