Alternative ways to power up pc from cold
  • Alternative ways to power up pc from cold
    Is there any other ways to power up pc than power button ?
    i got hp e-pc s10 that wont power up from power button at all, power button is dead. Broken sumwhere from the mobo :/ Is there any other ways to power up this computer ?
    I Know computer works, its just the damn power button thats broken :/
    do you still have the power button cable connected to the mobo. If so its easy as touching those two wires together for a second. A USDC or similiar would do the job of starting and stopping ur computer for you.
    Live mp3Car Facebook Chat
      Like i said, power button system is brokwen from the mobo. Those 2 pins are useless ... :/ I need alternative way, any ports or anything to start up ?
        Most newer motherboards have a wake-on-LAN or wake-on-ring feature in the BIOS. However, you've got to turn the thing on to be able to get into the BIOS to change those settings....
        Is there any of the pin(s) left that could be shorted momentarily to trigger a power on?
        How about the Wiki?
          Nope, i dont think there is. All the pins on the row are used to leds etc.
          How does wake on lan work ? Howto trigger it ?
            How do you know the computer works if you can't get it to turn on?
            Want to:
              After it went broke, i managed to power it up once with "power loss", ie i pushed power cord in and it started up...
              After i shutted it down next, i realized that it was power button system that was broken ... :/
                From my experience, you should be able to short the green wire on your ATX power connector (I'm making an assumtion there) to ground (the black wire next to the green), and the power supply will come on as soon as the switch on the back is turned on. I use a small piece of solid copper wire, but a paper clip will also do. At least that's how all of the ATX supplies I've dealt with work.
                Hope that helps,
                Walt
                Walts DC DC ATX Power Supply
                  I'm having trouble understanding what you mean by "power button system is brokwen from the mobo". Does this mean that the pins on the mobo snapped off, the switch is broken, or the pins don't do anything when closed?
                  If the pins snapped off, try jamming something into them - like a paperclip or a needle.
                  If you the pins (or parts of them) are still there, and you can bridge them with a wire or something, what happens? If nothing happens, try removing the CMOS batt for 20 seconds (or use the Clear CMOS jumper), replace the batt/jumper, and try the pins again.
                  IMHO - if something happened to shear the pins off, chances are the force did something else to the motherboard, too.... You might be out of luck...
                  http://www.jeepmp3.com/
                  CarPC Stolen. Starting over.
                  Ne1 recognize the avatar?
                    How about the Wiki?
                      The green wire on the PSU-Mobo (20-pin) wire will start the PSU up. But not the motherboard.
                      The power light, hard drives, possibly even graphics card, will fire up, but the CPU won't begin ticking until the motherboard tells it to. You can't just GIVE it power, it needs to be ready to turn on.
                      If you are good with circuitry, you may be able to trace the tracks along to the source of the problem, and trigger a power-on beyond that point.
                      Actually, having read some stuff it MIGHT work for you. Give it a go!
