Opus to computer & lcd power
  • Opus to computer & lcd power
    Is this a good idea? If not, what would be more logical?
    Yes, most of the members here (including me) power their LCD from the PSU. Read the sticky in the LCD forum, and see the choises.
    Renault Megane...the OEM look
      Yeah, but will I have a problem with the length of the cables? The blue lcd power line indicates lcd power and a long vga cable.
        One thing though...why is the LCD bigger than the battery?
          Hey, don't criticize my superior art skills
            No, basiclly if you run your wires though the side sills you can't have more than 5 m there btw, you'll be just fine. This is how I have mine. For the VGA cable it is reccommended o keep the legth under 5m, but there have been cases when someone run a longer VGA cable and had no problems. However I'd suggest keep it no longer than 5m, and use high quality cables, not only for the VGA but for most of your wires, as otherwise it may cause interference.
              I've got an ideea, draw the computer case, next to a drawing of your car. I'll bet it's as big...
                Yeah, my car is about 5m long I think so as long as I don't have to route it in a bunch of weird turns I should be fine. Thanks
