M1-ATX Case Incompatability???
  • M1-ATX Case Incompatability???
    M1 doesn't seem to fit in a Morex 3688 Case without removing the USB wiring/PCB from the front of the case? I'd like to keep my front USB ports. Any ideas???
    No need to remove anything but without major surgery you can keep only one front USB port operational.
    1- Remove the connector.
    2- Carefully bend the pins up enough to clear the capacitors.
    3- Plug the bottom row of the connector to the upper row of the pins.
    That is what I did.
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
