Difference between ACC and Ignition wire?
  • Difference between ACC and Ignition wire?
    somehow, i was wondering what's the difference between acc and ignition wire. I have being using acc wire in my setup. The acc get power when my key turn to ACC and cut the power when I crank the engine. what about Igntion wire???
    2006 Camry
    Compaq Laptop
    Holux GPS Iguidance 3.0
    7" Xenarc Touch Screen
    Carnetix 1900 Power Supplied, Wireless b/g
    I think ignition is live when key is in the "on" and "start" positions wheras ACC is live with the key in "acc" and "on" positions.
      Well, most people seem to call acc and ignition the same. They mean a circuit, or a connection to the circuit, that has power while the car is running. Usualy, if the circuit has power while the car is running, it will also have power when the car is off, but the key is in the acc positions.
      Sometimes, however, ignition does mean ignition, such as in a remote car start setup.
      Hope that helps
      Michael
        for our uses they are the same...
        the ignition or ACC line is off during cranking...
        Roy
        2005 Range Rover 4.4
          It is NOT really the same.
          for MOST cars (not all)
          ACC only turn on a the radio and aux/cig circuit. These circuits cut off during cranking. Only hot when the key is in ACC <=> IGN(ON)
          IGN turn on EVERYTHING in the car (ECU, CC, Power windows circuit, fuel pump, HVAC blower, .... you name it.) And none of these circuit is cut off during cranking. Only hot when the key is in IGN(ON) <=> START/CRANK
          So when hook up the car to our purpose do you want everything in the car to be ON when the engine is off just to listen to music or watching movie? The battery is sure to drain very fast.
          Y2K Accord Dell GX150
          EmoRebellion is a SCAMMER
            Actually the power windows and HVAC circuit are on one of the ACC lines. A lot of todays cars have more than one ACC line to accomodate the additional "accessories". The other thing is most cars have a latched output on the ACC lines where the radio, HVAC, power windows, etc. will stay powered until you open your door.
            ATVMS.com
              Every mfg does things differently.
              My car the ACC only turns on the radio. The "RUN" setting (second click) turns on everything else.
              My wifes car the ACC powers radio and windows.
              Having a factory electrical manual is almost required any more.
                ACC= Accesories: Radio, wipers, power windows,etc. OFF during cranking (some radios stay on, though)
                IGNITION(s)=Anything that the vehicle needs to crank/run:electrical pumps, ignition circuits, etc.
                  As you can see, while there are specific differences between ACC and ignition, most people think of them interchangeably.
                  Want to:
