OPUS 150W too much?
  • OPUS 150W too much?
    For a Xenarc MP-SC1?
    99 Grand Prix Grand Tigress
    HW
    Liliput 8in TS
    845GVD MITX w/ 2.4 Mobile P4M (478 MB)
    60GB 2.5" HDD
    MS MN-710 WifiG
    BT Deluo lite GPS
    IrDa PS/2 Keyboard
    SW:
    Win XP SP2
    RR
    IGuidance 4.0
    Zots day skin
    Proscan 4.0
    (100% Complete!)
    No way! but if it is a 19V input you should be looking at the new carnetix.
      It's a 12V input but I just notice the M1-ATX controller..which would be better, also looking not to drain my new Optima Yellow Top battery
      HW
      Liliput 8in TS
      60GB 2.5" HDD
      MS MN-710 WifiG
      BT Deluo lite GPS
      IrDa PS/2 Keyboard
      SW:
      Win XP SP2
      RR
      IGuidance 4.0
      Zots day skin
      Proscan 4.0
      (100% Complete!)
        Do a power budget for each rail (3V3, 5V and 12V) and see what you need. If the xenarc is 12V only in then all you need is one of the 12V carnetix, if not you need so hook up a full atx style (opus or M1). I would still go M1 though on a 1.3 unless it is a mobile or low voltage version.
          I looked at the carnetix 1260 but the relay issue and in-line fuses confuses me a bit.
          HW
          Liliput 8in TS
          60GB 2.5" HDD
          MS MN-710 WifiG
          BT Deluo lite GPS
          IrDa PS/2 Keyboard
          SW:
          Win XP SP2
          RR
          IGuidance 4.0
          Zots day skin
          Proscan 4.0
          (100% Complete!)
            OMG! learn then!
            whatever setup you use it is likely you wil have to use a relay and defintely an inline fuse (on the +ve lead as close to the battery as possible - if i had a 1 for everytime i have said that i would be rich).
            here is what you need to do:
            1. find out if the Xenarc is 12V only input (ie has its own dc-dc converters built in to generate the 3v3 and 5v lines)
            2. find out how much power it needs - the xenarc site should tell you
            3. find out how much that 1.3ghz p3 needs
            4. list what drives you are using - ie 3.5" hdd or 2.5", full size DVd or slim laptop DVD.
              1. Yes it's 12V only
              2. 60W
              3. It's a 1.3 normal so 30W
              4. DVD ROM slim. and 3.5 40GB HD
              HW
              Liliput 8in TS
              60GB 2.5" HDD
              MS MN-710 WifiG
              BT Deluo lite GPS
              IrDa PS/2 Keyboard
              SW:
              Win XP SP2
              RR
              IGuidance 4.0
              Zots day skin
              Proscan 4.0
              (100% Complete!)
                hmmm does the 60W include those drives? Coz the carnetix is only 60W and there is one with an extra 5V line that would power a usb hub and its devices nicely.
                If you went with an M1 or an Opus you would have to take the xenarc apart and remove the existing PSU - if there is an ATX connector on the board.
                  the 60W does include those drives but I have 3 usb ports.
                  1. USB BT for my Deluo GPS
                  2. MS 710-MN USB Wifi G
                  3. 8in Liliput Touch Screen
                  also the Xenarc doesn't have an ATX PSU.
                  HW
                  Liliput 8in TS
                  60GB 2.5" HDD
                  MS MN-710 WifiG
                  BT Deluo lite GPS
                  IrDa PS/2 Keyboard
                  SW:
                  Win XP SP2
                  RR
                  IGuidance 4.0
                  Zots day skin
                  Proscan 4.0
                  (100% Complete!)
                    if the 60W is total than you should get away with the Carnetix guess. have a look at what other people are using to power their xenarc PCs. If you get the carnetix with the extra 5V rail it will be perfect for powering your USB devices however you will have to find another 12V suppy for your screen.
                      Cool, I think I'll run my screen on the cigarette lighter.
                      HW
                      Liliput 8in TS
                      60GB 2.5" HDD
                      MS MN-710 WifiG
                      BT Deluo lite GPS
                      IrDa PS/2 Keyboard
                      SW:
                      Win XP SP2
                      RR
                      IGuidance 4.0
                      Zots day skin
                      Proscan 4.0
                      (100% Complete!)
                        please read the thread on powering your LCD 1st! make sure your have some sort of regulator for the screen - i dont know if the eggs are better these days.
                        And please check to see what other people are suing to power PCs like yours before you commit to the carnetix.
                          I have to regualte that too? Moreso than the egg provided?
                          Well the Xenarc has the sumicom board and that's what a guy from Carnetix said is the better bet unless I can get teh Opus and power the screen and PC both from the OPUS 90W. Hence why I initially thought the 150W may be ok but possibly overkill.
                          HW
                          Liliput 8in TS
                          60GB 2.5" HDD
                          MS MN-710 WifiG
                          BT Deluo lite GPS
                          IrDa PS/2 Keyboard
                          SW:
                          Win XP SP2
                          RR
                          IGuidance 4.0
                          Zots day skin
                          Proscan 4.0
                          (100% Complete!)
                            dude. the opus 90 and 150 are ATX powers supplies so you would need to replace the ie in the Xenarc to use the. Their 12V lines are not powerful enough.
                            I actually think this might be your best option: http://www.mp3car.com/store/product_...products_id=97
                            it is an 80W opus 12V psu. It wont have a 5V line for your GPS but it should be ok off the PCs USB. The 80W will be ok for your CP with a bit of margin and you could also possibly have enough left over to power the screen.
                            There have been problems with eggs on screens but by all means try it.
