Anyone seen this 12v DC-DC ATX power supply?
  • Anyone seen this 12v DC-DC ATX power supply?
    http://www.voxtechnologies.com/Power...es/vtc0144.htm
    I was quoted just under $200. I may give it a try instead of the inverter/120v PSU route.
    it looks like a keypower. there cheaper then that other places i found, i guess they dont servive angine crank and they have no startup/shutdown controller
      Some people say that they survive engine crank.
      PowerVoice v1 | NaviVoice Source
      GammaControl v2.4
      SKINbedder v3
      1995 Lexus SC300
        I'm not to terribly concerned about it surviving crank because if I'm in the car its going to be running. Being in the middle of the desert you dont really want to sit in a car without the air conditioning going . Again not really concerned about a shutdown controller either. Starting up and shutting down manually doesnt bother me much.
        I found a interesting PSU on ebay today that I decided I would try.
        http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
        I'll let you guys know how it works out. It should be enough juice to power my system.
        Asus A7V400-MX board
        AMD XP 1800
        256Mb Ram
        Onboard Video, Audio, Lan
        802.11g PCI card
        92mm Zalman Heatsink
        2 50mm fans, 1 80mm fan.
          AMD XP 1800
          256Mb Ram
          802.11g PCI card
          LOL that wont even come close to powering your system. Its not really 200w. Learn to research first before impulse buying.
          Opus 150
          Keypower
          Sproggy
          are you your options your looking at around 200 bucks
            Opus 150
            Keypower
            Sproggy
            Care to explain at all? Or are we just making assumptions? The item is described as a 200W ATX power supply.
              Here are the specs
              for your special power supply needs
              PW-200M SPECIFICATIONS
              Volts (V) Max Load (A) Peak Load (A) Regulation %
              5V 6A 10A +/-5%
              5VSB 2A 10A +/-5%
              3.3V 6A 10A +/-5%
              -12V 0.1A 0.2A +/-10%
              12V 12A 13.5A N/A
              Power Ratings (Max. Power = 205 Watts)
              Efficiency Ratings
              Dimensions 61mm (L) X 57mm (W) X 30mm (H) (1U compliant)
              DC-Jack 2.5mm X 5.5mm X 10mm
              ATX connector Molex 39-01-2200
              Overload Protection Over load protection will be effected when either of the loads (+5V & +3.3V)
              exceeds > 200% Max Load.
              Turn-on Delay After turning on, at least 20ms will be needed for the rise of +5V output voltage (measured from 10% point to 95% point on the waveform) to reach its peak.
              Remote ON/OFF control
              Logic level is LOW - Output voltage is enabled.
              Logic level is HIGH - Output voltage is disabled.
              Operating Environment
              Temperature 0C -75C (32F -167F)
              Relative Humidity 10%-90%, non-condensing
              Altitude 50,000 ft.
              Efficiency Over 95% at full load
              Shipping and Storage Temperature -40C- 90C (-40F -194F)
              Relative Humidity 5%-95%, non-condensing
              MTBF 200,000 hours
              Warranty 1 Year
                http://www.mp3car.com/vbulletin/show...hlight=PW-200M
                You'd do well to ignore the backbiting in that thread....
                How about the Wiki?
                  Thanks for the info DarquePervert! It was actually informative. You could have just been an *** and laughed like someone else I know.
