The Cnx-p5v 15 Watt +5v Regulator
  • The Cnx-p5v 15 Watt +5v Regulator
    http://www.carnetix.com/P5V.htm
    Does this mean I can basically have 6amps of 5v power (if i select 19v/5v from main unit, and install this addon)? That was my only issue with buying this P1900, i needed alot more than 3 amps at 5v
    Well....yes, but they cannot be combined into a single +5V output. They are two seperate +5V regulators. However, depending upon what you are powering, you could split the load. For example, you could use one +5V output to power some of your USB devices, and the other +5V ouput to power other devices.
    ....does this help?
    MikeH
      I suppose... I do have two usb hubs, i suppose it could just power each individually
      thanks!
