Opus and IBM Think Centre
  • Opus and IBM Think Centre
    I have an IBM ThinkCentre and an Opus 150.
    My problem is that the mobo doesn't have anywhere to connect the green and white power up wires.
    The IBM has 2 normally open contacts on its Power Switch, rather than 1 normally open, and these connect via an 8 pin plug that also connects the Power and hard drive LEDs to the mobo.
    What I need to know is how can I mod this to make the Opus work with it?
    It seems to me I could do this with a relay. 2 issues with this:
    1. What is the output of the green and white wires? What could be connected to it? I know that it is polarity sensitive.
    2. Reading elsewhere in the forum the Opus needs to know that the green/white cable is connected to the mobo before it will power up? What is it looking for?
    I have emailed Opus tech support twice and so far not received a reply.
    Any ideas anyone?
    good luck getting a reply from opus.. why don't you try carnetix.. they are very helpfull and prompt..
      call opus
