Bridge batt power for relay switch?
  • Bridge batt power for relay switch?
    Okai at the moment i have my inverter hooked straight up to the battery. Fuse at the battery end of power cable.
    Just before the power reaches the inverter i have a relay which is hooked up to the acc line.
    So when i crank my car, the computer reboots, not because of low voltage but because acc line cuts out when cranking.
    So instead of using the acc line, can i splice the power cable that goes to the relay and just hook the switch at my dash to this and then to the switch on the relay.
    So basically i just replace the acc line thats switching my relay with a permament batt line.
    This should be okai yes?
    can you just put a delay on that? maybe a simple cap and resistor? that way the relay would stay open during crank?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
      here are a few links to show you how to do it:
      http://books.mcgraw-hill.com/authors/cutcher/RCI.html
      http://www.technologystudent.com/elec1/capac1.htm
      http://www.technologystudent.com/elec1/capac3.htm
      M10k
      My Car Pc Install
      My Boat Pc worklog
        mmm, thank you, never thought of that, will do.
          Actually i want to be able to keep the comp on when i take the keys out, say i go to fill up petrol i dont want to leave my keys in the car.
          So for this i need the power for the switch on the relay hooked up to a permament 12V.
          So is it safe to hook the relay switch line directly to the battery with a small switch inline so i can switch the relay open/closed?
          Also does the acc line become a 14.4 volt line when the car is on because of the alternator, or does it stay at 12?
            I believe that the Acc. line stays 12V because it is regulated by the voltage regulator. I think this is true. If someone could verify this that would be nice .
            BTW; I'm new here. Hi!
