opus 120 problem
  • opus 120 problem
    I just installed evering thing today...
    Here's my setup:
    4G wire
    Remote to subs
    Epia 800
    512 pc133
    40G notebook HD
    Slot loading DVD/CD-R
    USB Hub
    2 L.E.D. Fans
    XM
    TView wiried to the Power Supply
    USB GPS Mouse
    and.....OPUS 120
    I power everthing and worked like a charm...powered up/Power down. After twicking the screen and RR, I rebooted....did not power up
    Now I pulled the PC inside my house and it powered up. No LED on OPUS....Did I burn the OPUS????
    Crazy Miami Drivers
    R.I.P. My first ever NEW Car
    Old installation
    New Install!!!
    |-------------------100%|Cables ran
    |----------------85%----|Software RR
    |--------------80%------|Complete
    [/SIZE]
    You checked the cables going into the Opus right?
    Installed.
    -GPSSecure- - GPS Tracking
      Check the fuse inside the Opus, or any fuses you have inline to the Opus too
        Check all fuses....there all good
        Crazy Miami Drivers
        Old installation
        New Install!!!
        [/SIZE]
          And all your connections? especially any splices?
            I checked everthing....all connections, fuses..I unpluged everthing and reconnected....Here's how I have it wired...
            4G-----140fuse----4G------3 way Disto Box (40fuse)----PC
            4G-----140fuse----4G------3 way Disto Box (60fuse)----4Ch Amp
            4G-----140fuse----4G------3 way Disto Box (80fuse)----2Ch Amp
            It worked fine for about 1/2 hour while I worked on the touch screen
            Crazy Miami Drivers
            Old installation
            New Install!!!
            [/SIZE]
              Sounds like it might be dead if you aren't getting any lights and all your connections are good.
              Installed.
                do you have a volt meter/multi meter? Check the voltages on your lines. With the car off you should have the following
                Yellow~12V
                Red~0V
                With the car running you should have
                Yellow~14V
                Red~12V
                Give or take.
                  I know I mentioned it once, but did you check the fuse on the Opus itself?
                    Yellow~12V
                    Red~0V
                    Yellow~14V
                    Red~12V
                    Give or take.
                    I have not tried that...My volt meter is somewhere/someone has it....
                    I tried looking for....Since I did not find it I turned to the "Pros"
                    Crazy Miami Drivers
                    Old installation
                    New Install!!!
                    [/SIZE]
                      Oh, I thought that you did this since you had mentioned you had checked your connections Ya, definitely check that.
                      Installed.
                        Yup I pulled it out and checked it...it was good
                        Crazy Miami Drivers
                        Old installation
                        New Install!!!
                        [/SIZE]
                          Let us know what happens when you meter the lines. Once you find your MM
                            Question...with the stuff I have (on my first post) will the opus 120 handle it?
                            I know...noon question...just wanna double check...
                            Crazy Miami Drivers
                            Old installation
                            New Install!!!
                            [/SIZE]
                              It seems like it should.
                              I've got an OPUS 150 running:
                              P4 2.8GHz
                              512MB RAM
                              ATI Radeon 9250
                              120GB Maxtor 3.5" HDD
                              External USB DVD enclosure
                              GPS Mouse
                              USB wireless card
                              DWW-7VGA
                              All powered from the OPUS. It's running just fine. So your setup shouldn't have any problems
