New Mpegbox Power Supply
  • New Mpegbox Power Supply
    Hey All,
    Your prayers are about to be answered.
    Here your looking at the new DSATX Durawatt power supply from Mpegbox.com
    This power supply has the following specs:
    8-16 volts in
    12V @ 11 Amps
    5V @ 11 Amps
    3.3V @ 10 Amps
    5VSB @ 1.5 Amps
    -12V @ 0.15 Amps
    I am going to call it a 220 watt DC-DC power supply.
    Here it is powering a P4 motherboard and hard drive with an 8 volt input:
    Here is the P4 motherboard on the BIOS and my Main PC on the right, it is connected to the power supply with hyper terminal:
    Here is what the power supply is currently spitting out of the serial port every 100 ms:
    Basically this is as follows
    Temp in Degrees C : Input voltage : 12 volt rail : 5Volt rail : 3.3Volt Rail : Pot1 : Pot2 and the YYYN means all the rails are within 5% except for the input which is 7.14 volts (and powering a P4 by the way...)
    This power supply is very very efficient, has a very beefy 12 volt rail, and will have by far the best serial port diagnostic and programmable shutdown controller on the market.
    Any takers? :-)
    -Jeff
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    How much are you going to be selling it for? Just asking
    PowerVoice v1 | NaviVoice Source
    GammaControl v2.4
    SKINbedder v3
    1995 Lexus SC300
      Probably around $150 - $200.
      www.mpegbox.com
        Ok......
        RexBruMet Skin for FrodoPlayer
        Nissan Aux-in MOD
        Originally posted by bgoodman
        We're an international forum, post in whatever langauge you like.
          looks good!
            looks nice.. what are the dimensions?
            Dr. Ron Paul for President 2008
            Hope for America - http://www.ronpaul2008.com
            Who is Ron Paul? - Why do we need Ron Paul?
            CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
              when you need some (unbiased) one to conduct real world testing and a lengthy write up, let me know
              Looks very nice
              Is this where the witty comment goes?
              97 Black pearl Mazda Miata MX-5 Carpc V2? maybee..
                damn that thing is tiny! how the hell did you make it that small and 220W? Will it need any active cooling?
                  If you only use it for 100 watts you don't need a fan or anything. If your going to go over that, a fan is going to be needed. It didn't even get warm powering my 2 gig p4. It was only pulling about 90 watts in idel mode..
                  www.mpegbox.com
                    any plans to fit heatsinks etc etc?
                      It has heatsinking in the board. I am going to design a case for it. That will have a 40mm Fan, it is >95% efficient. None of the parts generate more than 1.5watts of heat.
                      www.mpegbox.com
                        yeah i have been watching your 12V only dc-dc closely and was impressed by the efficiency of that.
                          3.5" by 4.15"
                          www.mpegbox.com
                            Looks damn good, finally a ONE PIECE solution for powering bigger P4's and AMD's.
                              how "tall" is the board w/ components?
