Inverter Relay!
  • Inverter Relay!
    Hi, first of all i have searched and i cant find anything on this...
    I have the usual;
    12V BATTERY --> INVERTER --> PC
    when the ignition is on i want the battery --> inverter connection to be closed. The problem is the current... i guess i need one MASSIVE relay, as the inverter will draw alot of power! I want it to intercept the inverter connection because the inverter draws current even when the connected appliance is not turned on.
    Any idea's, or links?
    Dean
    the inverter must have a power switch... just wire the relay across that. sure an inverter draws a lot of current, but you can get automotive relays rated to 20 or 30 amps easily enough...
    But don't take it from me! here's a quote from a real, live newbie:
    Originally posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
      Yeah I did it this weekend. I used a 30 amp automotive relay from radio shack. It works well. You can take the accessory wire and run it to the 12V+ in on the coil on the relay and ground the other side. After that wire up the switch on the relay in line with the switch on the inverter and just leave the inverter on. In my inverter the switch must not carry all the current because the wires to the switch were tiny so I wouldn't worry about current.
      How does your inverter draw current when it is off? I have had no problem with this and my car sits for days at a time without being driven.
      Xenarc 7" USB Touch LCD / 3.06 GHz P4 / 512MB DDR / 250GB 7200RPM 16MB HD /
      DS-ATX 220W / Centrafuse / GPS / XM / 802.11g: 6db / RF Keyboard
        pastypyro, when the igition is off, the relay should turn off the inverter, too, right? That way, the inverter can't draw any power from the battery. I think that's the best set up with inverters.
        iGMon - Integration between iGuidance and Road Runner
        CFX - Skin for Road Runner
          what he's talking about is if you leave the inverter on with whatever is plugged into it turned off. then the inverter would still be running to maintain 120VAC on its output, even with no current draw, so it would still consume some power, and if it's a real cheap inverter it might consume a decent amount
          and I would imagine that on most inverters, like yours pastypyro, the power switch is just powering the control circuitry, not actually carrying the full current load of the inverter, so a large relay should not be needed.
          eegeek.net
            I don't have this problem. I'm not sure if I got lucky with buying this inverter or what. I know the switch doesn't carry much current now, but I didn't before I opened it up. I bought the relay before that. Good luck.
              the inverter does have a power switch...
              so when the inverter switch is OFF does it consume any power?
              dean
                dean
                I think it depedns on the inverter. When mine is switched off and the computer is still plugged in I have not had any problems with it sitting like this for at least a week. If there were any current draw issues I'm sure they would have turned up then.
                Hopefully more will jump into this conversation and discuss the other possibility. But, the only way to know is to try it.
                  dean
                  Probably not. I say probably because it is possible that the inverter circuitry may monitor the switch to see if it is on or off. That would consume a very small amount of power.
                  The way to test this is to hook up your digital multimeter (you have one, right? If you have a computer in your car, you are obligated by law to buy and know how to use one :-) to measure the current draw. Turn the switch on and the computer on. Measure it. Shut the computer down, measure it. Turn the inverter switch off. Measure it.
                  Then you'll know for sure.
                  Want to:
                    yeh ok cheers guys! Thanks alot!
                    Dean
                      does anyone here have an amount for current draw from their inverters when the engine is off?
                      just for the record
                      if it is comparable to say, an alarm system or the digital clocks in the car, then you have nothing to worry about
                      [||||||||||||||||||||] - final touches
                      SUPER 7" VGA w/ TS
                      Toshiba Satellite 3000
                      P3 850
                      256MB
                      30GB
                      Geforce2 Go
                      DVD
                      Orinoco 802.11b PCMCIA
                      nlite WinXP 350MB installed
                      RoadRunner
                      iGuidance 2.1
                      Holux GM210 GPS
                      Xantrex Xpower 300
                        Stinger makes the perfect relay for this application. Its the SR80 and handles 80 amps. I use one and it works great. You can find them on ebay for less than $20 shipped.
                          i actually cant find this item. you got any links?
                          dean
                            You just need a 12v automotive relay, one's usually used for fog or driving lights works fine. I use this shutdown designed by Laidback http://www.mp3car.com/vbulletin/show...t=ups+inverter
                            It works perfect. I used the fog/driving light relay for the power to the inverter and a very small 12v relay that I got from Radio Shack for the serial port.
                              I would be careful using a relay that isnt designed for the wattage that a inverter pulls. Thats a good way to end up with a fire in your trunk. Also, you dont want your relay to be a restriction of power flow in your system. Whats the point of bringing a 4ga wire into your trunk when your going to restrict it with a small relay?
                              Here is the link to an auction by the same guy I bought mine from. Ships quick and is easy to work with.
                              http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
                              A lot of guys use these when integrating another battery into their car audio system.
