Shuttle SN25P proprietary plugs! arrgh! Need to adapt/make a Car PSU for it
  • Shuttle SN25P proprietary plugs! arrgh! Need to adapt/make a Car PSU for it
    Hi all,
    long time lurker, first time poster. I'm building my carputer, and chose a shuttle xpc SN25P, which seems to have it's own funky power supply that is possibly not compatible with the opus. It has 2 plugs which have "12Vsb" (for 12 Volt standby?) wires and ground wires on them. No 3.3 V lines, no -12V lines, just +12V "standby" lines.
    I would like to adapt an existing car Power supply such as the Opus to deal with this motherboard, or make my own, since it IS 12 volts.
    Could I have some assistance / tips on how to adapt an ATX or ATX+12V power supply to this, or does anyone know of a power supply I could purchase to support this computer?
    Thanks!
    A description of the power supply in Shuttle "P" series cases is here:
    http://www.silentpcreview.com/article229-page3.html
    (that computer has the same power supply)
    www.speakwithme.com
    2004 Infiniti G35/Focal 165 K2P front stage /Focal 165CV rear/JL 10W6 sub/Shuttle PC in trunk/Alpine PXA-H701/Alpine DVA-9860.
    use the pin assinment chart to splice in your opus if you can.
      If you want a real clean solution Id get a female ATX connector to plug into the Opus' ATX connector. Then from the female ATX connector attach the connectors that are on the Shuttle PSU. Find the parts on the Molex site, they're on there somewhere, just have to look
      2004 G35 Coupe project
        I went to an electronics supply store and found a couple of the plugs yesterday, need 2 more and I should be all set! Thanks! I just wanted to confirm that I could just run the wires with the right voltages and connect everything that way
        www.speakwithme.com
          what is the total power of +12v and the +12SB?
          I can make one for you at the size about 30mm x30mm x50mm
            it looks like splicing the opus is a bad idea. dragonBTV, you have a PM
            Here are the power supply specs from shuttle:
            Shuttle SB81P Power Supply, Model PC43I3503
            AC Input
            100 - 240 VAC, 50-60 Hz
            DC Output
            +3.3V, 3.5 Amps, 18 Watts max output
            +5V, 3.5 Amps, 18 watts max output
            +12V 3.5 Amps, 42 Watts, max output
            +12Vsb connector A, 17 Amps, 204 watts max output
            +12Vsb connector B, 17 Amps, 204 watts max output
            Total Power
            350W
            www.speakwithme.com
              you could use a low-wattage ATX DC-DC supply (like the M1-ATX or something), and a separate 12v dedicated DC-DC for the 12Vsb lines. (several dedicated 12v output supplies are available)
              that seems like the easiest way...
              But don't take it from me! here's a quote from a real, live newbie:
              Originally posted by Viscouse
              I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
              eegeek.net
                what dedicated 12Volt DC-DC power supplies are available? I don't know of any...
                www.speakwithme.com
