m1 atx 90watt...is it for me?
  • m1 atx 90watt...is it for me?
    Hi,
    I'm a newbie I post from Italy...
    I have a problem with a power supply, I would you like to know if the power supply "m1 atx" is good for my hardware:
    -pentium3 800 Mhz
    -256 Mb pci133
    -HD 2.5" 40 Gb
    -DVD rom 16x
    -mouse gps usb
    -video and sound integrated
    Can I use this Dc-Dc??
    Thanks and sorry for my english....
    We!!!
    Ciao!! Compaesano!!!
    Io sono di Verona e tu? Ti lascio il mio contatto msn: mgcomp@passport.com
    M1 atx 90W dovrebbe bastare per il tuo hardware, al max ci alimenti solo la scheda madre e il resto lo alimenti con degli stabilizzatori da 5v e 12v.
    Ciao!!!
      yup. it's fine.
        Eh...
        Ciao compaesà, io sono di Roma...dici che basta? come faccio ad alimentare il resto con gli stabilizzatori?!?
        E se per il dvd usassi un'altro ali tipo il pw70a con itps? Si può fare?
        Ti lascio la mia email: psyco82@yahoo.it
        Ciao.
          Originally posted by Scouse Monkey
          yup. it's fine.
            Originally posted by psycos
            YES!
            M1-ATX = OK!
              YES!
              M1-ATX = OK!
              ok thanks, but if I use a dvd rom for pc (5.25"), is it ok?
                I knew you were going to ask that.
                it should be because you are using a laptop HDD. If you get any problems that would be my 1st thin to try unplugging. You could always go with an opus 120 but the M1 should be enough.
                  I haven't tried it with that exact combo but yeah the M1-ATX has given out on me trying to use a full-size CDROM and HD. Mind you I've also got two PCI cards on it (MII-12000 with dual riser).
                  Silverwolf 2 is dead.
                  Silverwolf 3...?
                    I think that I must use another power supplies for the dvdrom...
                    Another solution is the Opus but here, in Italy, it is very expensive!!!
                      I should think it will be fine as it is your only 12V device.
                      Best advice would be to try it and see. If you have problems pick up a cheap laptop drive but I doubt you will.
                      People have run more demanding systems on an M1 so give it a go.
                        ok, better feedback in this thread. gonna orders soon and i dont know if my M1 is sufficient.. Take a look please =)
                        Im gonna get the ampie case, thats it but after reading in this thread i dont know if the M1 ATX is sufficent.
                        I will connect following
                        VIA EPIA SP13000, m/Via C3 CPU 1300MHz Mini-ITX,DDR400,VGA,Tv-Out, Firewire
                        Crucial PC2100 DDR-DIMM 512MB CL2.5. Non-parity, 2.5V, 64Meg x 64
                        SATA - Samsung SpinPoint M40S 80GB 5400RPM SATA2 2,5" 9,5mm
                        IDE - Pioneer Slot Load DVD±R/+R DL/±RW Dual Drive 8X "Slimline"
                        USB - A 7 Avator 7 tft Touchscreen, screen and usb connected
                        USB - 3COM OFFICECONNECT 11G 108MBPS WIRELESS WLAN
                        USB - GPS, The gps has batteri but recharges via usb.
                        USB - Remote controll later on
                        according to power guides its near the edge hehe but the slimline DVD writer is the only 12 V. And most of the USB gadjets uses only a few hundred milli ampere
                        What do you think..
                        Ampie Case
                        M1-ATX 90w
                        EPIA ITX 1,3Ghz, Firewire
                        80 GIG SATA
                        512MB
                        7 TFT Touch Super
                        Pioner Slot in DVD-RW writer
                        108 Mbit Wireless Lan
                        100 M Bluetooth Range
                        //Power Nisse
                        My Betasite -> http://haagen.se
                          Should be fine. (but same again - weigh up the cost for the extra 30W out of the opus 120 compared to postage etc)
                            Ueee paesà... stò lavorando ad un PSU che non sia fatto con i soliti integrati della Maxim, utilizza infatti un comunissimo sg3524, funziona molto bene e riesco ad ottenere un rendimento medio vicino al 85% ma il problema è che utilizza delle ferriti da ampli car, difficili da trovare, stò sperimentando con delle ferriti prese da alimentatori PC... è un pò più complicato (lavorano ad una frequenza + alta) ma almeno le ferriti si possono trovare agggrrratis, basta andare in qualsiasi centro di raccolta rifiuti e gli alimentatori da PC te li tirano dietro.
                            Penso in un paio di settimane dovrei riuscire (se mi arriva l' oscilloscopio che ho in riparazione) a testare e postare uno schema definitivo, magari con lo stampato bello da stirare (metodo stira ed ammira) come da esempio che trovi qui: http://www.baronerosso.net/mod-subje...ageid-167.html
                            Per ulteriori info puoi contattarmi all' indirizzo: sandroexs@yahoo.it
                            Dice il saggio:
                            Due cose sono infinite, l' universo e la stupidità umana...... e non sono sicuro della prima. (A.Einstein)
                              eh?
