Casetronic Power Supply Problem
  • Casetronic Power Supply Problem
    I have a Casetronic case with a built in power supply and external brick that I just got. When I connect the brick to the wall the light on it is on but doesn't seem too bright and flickers. If I connect it to the case (containing an M10000) it flickers more and the PC will not turn on.
    If I check the voltage on the plug that connectes to the case it shows 3V DC where it should be 12V.
    Is it garbage? Should I just trash it or is there anything else worth checking? It isn't the end of the world as I am going to use an Opus but I thought this would be nice for configuring in the house.
    Chris.
