Opus 150 -Ignition failed
  • Opus 150 -Ignition failed
    I have the Opus 150 psu, i have everything conected inside the car (12v, ground,ignition).
    The problem is that the Opus acts like having no automatic shutdown, when i turn on the Key the computer doesnt boot and when its on it doesnt shutdown when i turn off the car.
    The ignition wire i use is the same as my Headunit use(and it works fine with it).
    Does anyone experienced anything like this ???
    The only thing that helps is that if i double click my mouse the computer turn on , but the shutdown must be manual
    Here in Portugal we have great weather, lots of brunnets, party a lot,drink a lot....
    http://img138.echo.cx/img138/896/bannerjoshua5dy.jpg
    sounds like an issue with the motherboard pins
    PC Components:
    My work log
      Make sure the white\green wire is hooked up to the mobo correctly.
      Renault Megane...the OEM look
        Originally posted by Enforcer
        Have you checked the DIP header settings to make sure you have selected shutdown mode.
        I thought that all opus 150 had that setting as default...
        How can i know the settings, opus came without instructions or manual....
        I had a PDF file, but i cant seem to find it
        "Make sure the white\green wire is hooked up to the mobo correctly."
        I dont have it conected to the motherboard right now because if i do that i can not start the computer with the double click on the mouse....
        Thanks for the quick answers
          If that white\green cable is not connected it is normal that it doesn't shutdown,that is the cable that signal the mobo to shutdown the pc.
          Download our catalogue here :
          http://www.noboringstuff.com/catalogoweb.zip
            i have the pdf manual tried to upload it in a zip file but max is 200kb and this zip is 201kb so if you want it i could mail it to you
              I know that, but it didnt work with wire conected to the motherboard either, so in order to start the computer by double taping the mouse buton i had to disconect the green/white from the motherboard....
              When i try to activate the automatica shutdown/startup i always conect the wire to the mobo.
              ste1806 - You got Pm
                try the green / white cable the other way round, its the wrong way round it wont do anything.
                Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
                PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
                Toys:K8055 relay board, Elmscan OBDII
                Type-R Mini
                  http://mvaras.workisboring.com/serve...r%20Manual.pdf
                  Thats the Opus 150 manual
                    I have noticed this, Why is that? When i work on my carputer in my house i just short out those pins to turn it on, why does the oreintation matter.
                    How does it work?
                    My OLD carputer page
                    My NEW carPC
                    Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
                      How does it work?
                      Electricity. Positive and Negative. They have to be right. Or current will not flow. I had the same issue, just flip the connector around 180.
                      2003 Black Impala
                        yea, i noticed this with mine too. drove me nuts.
                        so stupid, it really should just be a relay that closes like a momentary switch. whatever tho.
                        my little rule for pulling the cable out is green to the pci. opposite from what you would think, white to the pci. but its all cool.
                        it might be different for you depending on what mobo you have, i have the p4 870 mini itx found in the store on this site.
                        1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
                        Pictures
                        Photobucket is being updated, if a picture i posted no longer works, please PM me.
                          I know electricity, what im saying is when i at home I just turn my mobo on by touching tweezers to each jumper. Does the opus have the current from the mobo flow trough it to turn it on or does it just short it out. Do you get what I'm asking?
                          My NEW carPC
                            If so many people hadn't said that they also noticed this behavior, I'd have called BS. You're right - normally you'd expect the wires to just be shorted like a normal computer case power switch does. After taking 15 seconds to think about it, I can only conclude that the opus uses a transistor to operate the power switch. This would mean that the wires need to be connected a certain way so that the (extremely tiny amount of) current is able to flow from the mobo, through the transistor, back into the other pin on the mobo which is what powers it on. Think of a transistor as a much smaller (potentially microscopic) relay, only the catch is that current can only flow one way.
