PW-120 mod?
  • PW-120 mod?
    Okay, so I got a PW-120 from a member here and turns out its made specifically for the EPIA mobos. I saw there was a mod where you could make the rail go up to 16v. But is there a mod that will let me use this PSU on a mATX?
    If you mean running pw120 with a micro atx mobo check out this online manual: http://www.cartft.com/support/doku/m..._dl/PW120M.pdf
    I think that it says that is capable running on atx mobos just using a mobo cable extension and one more p4 4pin connector (you need to solder that)...
    Correct me if i am wrong...
