Where do I get 5v from car? (for USB hub)
  • Where do I get 5v from car? (for USB hub)
    Where do I get 5volt from my car to my USB hub?
    I have a Volkswagen Golf GTI -99
    with a power regulator or a power supply
    Progress,.... that is what I keep forgetting ;)
    planning_[++++++++++]. 110%
    parts___[++++++----] around 60%
    install___[-----------] -9,000%
      from your PCs power supply
      Pioneer DEH7600MP, Autotek MX-800.4, JL Audio XR650-CSi, Adire Audio Shiva
      Done with CarPCs, using a iPaq 3765 PDA w/ Holux GM210 and TomTom
        i dont want to use my power supplt for my PC.
        Is it possible to get 5v from the car? or is everything 12v?
        I use M1-ATX for my PC and i think i have used alot of 5v
          car voltage is all around 13.8v while running... you'll need a power regulator, u cang et them quite cheap with plugs on designed for small electronic appliances like usb hubs.
          Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
          Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
          CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
          http://www.no1knows.com/galleries/
            http://www.opussolutions.com/modules...article&sid=26
            How about the Wiki?
              Use one of these.
              Want to:
                7805 voltage regulator will convert 12v to 5v at the apparent expense of some heat
                  The Opus POL DC-DC seems to bee a good option for the 5v.
                  The problem is where to get hold of it in Sweden. I will search here in Sweden.
                  I saw there are 2 models of it one with "mounting bracket/heat sink" and one without. Anyone who has one of theise, and how does it looks?
                    so if i buy one of these, i can connect my external audigy 2 nx soundcard because it takes in 5v input ? I am very reluctant to splice the wires on the power pack of my audigy 2 nx and hook it up to one of these. Theres got to be a easier way
                    I'll be using a M1, is there any way to get 5v power from it when the comp is on ?
                      m1-atx
                        Originally posted by cyrax83
                        so if i buy one of these, i can connect my external audigy 2 nx soundcard because it takes in 5v input ? I am very reluctant to splice the wires on the power pack of my audigy 2 nx and hook it up to one of these. Theres got to be a cheaper easier way
                        cheaper? the 7805 will cost you like 50 cents (except at radio shack where you'll find the usual 300% to 400% inflation)
                        easier? well I guess if you are afraid of soldering, then I can see why you'd avoid it. but the entire circuit consists of the regulator, and a couple capacitors... could be build in 15 minutes... and with a multimeter you can easily verify that it's outputting 5v before you go hooking it up to the audigy, therefore there isn't a lot of risk...
                        But don't take it from me! here's a quote from a real, live newbie:
                        Originally posted by Viscouse
                        I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
                        eegeek.net
                          I remember reading about a mod with a lilliput 12V adapter and it being modded to out put only 5V, Maybe I'm dreaming but I can't seem to find it right now.
                          Remember AllAdvantage From 7 years ago? IT IS BACK! Now under a new name Agloco
                          GET PAID TO SURF THE INTERNET
