wires again
  • wires again
    Yeah I searched and did not turn up much.... anyways
    Will I be fine running 4GA from battery to D/Block then 8GA to my computer and 2 AMPS ?? Should I run 4GA for my grounds to ?
    It depends on the amps, are they powerfull amps?
      nope... just 1 to power normal speaker in the car and 1 amp to power 1 sub
        bump.... sorry just want to make sure I am doing this right. 4GA to 8GA
        D.Block to:
        1x Computer
        1x 4+ Amp (300watts)
        1x Mono Amp (400watts)
        8GA going to be ok?
          8 guage is find for 400 watts. You could probly get away with 8 guage going to distobution block. But its always better to be safe with a larger wire. Just make sure the fuse for your wireing kit is large enough for all your electronics. Add your fuse rating for the two amps together, and add the amperage for the power supply (wattage / input voltage ie 12-14v). That will give you the total amperage of your system. Try to get a fuse as close to that number, but larger than it as you can.
