opus 120w jumper help
  • opus 120w jumper help
    I just wired up my opus to the computer and turned the car on and the computer wil not boot?
    Do i need to add or switch any jumpers on the opus for it to work correctly or could anyone help me with the jumper and my problem.
    i found this thread with some of the jumper setting but there are more than just these ones.
    http://www.mp3car.com/vbulletin/show...light=opus+120
    i measured all my voltages going to the opus they are correct.
    thanks nick
    I was going through the same thing last week. Opus suggests using an AC powered supply to set up the bios. Just got home, haven't solved it yet. I did get the supply to start up by putting in the jumper that changes it from ATX to AT mode, disables handshake. I was using an LCD monitor. There is a bios setting for CRT or LCD monitor, maybe I have to use a CRT to get into the bios; had to buy a PS keyboard because the USB keybord is by defaut turned off. Also, (PD10000 board) I found that, as others have posted, the CLEAR CMOS jumper is factory installed at the CLEAR CMOS position. barf.
