Battery
  • Battery
    Hi does anyone suffer from a flat battrey using the opus 150? my computer is set to standby, and overnight my battery goes flat. i thought opus had protection to prevent this?
    I have an Optima yellow top and have left my car for multiple days on end with an Opus 150, Never had a problem. Do you have a decent battery, or is it old and the original that came from the car maker?
      umm, you leaving it on standby which will drain the battery pretty quickly. I suggest you use hibernation, it won't drain you battery as much. Most people put their computer to hibernation. Just do a little search and you'll see the different options people use and their pros and cons.
      Installed
      Asus A7N8X-VM - AMD Mobile Athlon 2400
      512 Ram - 60GB HD - Opus 150w
      Lilliput 7" - Rikaline 6010
      [00000000000001100010-] 98% Completed
      Check Out My Install!!!
        Holy ****. I bought the best battery at my local car shop. but its a normal battery. Now a really want an OPtima batteri.. Standby in several days hehe
        I have buildt an alarm now works great but drains the battery alot :/
        So the yellow is enough, im considering the red one maybe hehe
        //Power
        Ampie Case
        M1-ATX 90w
        EPIA ITX 1,3Ghz, Firewire
        80 GIG SATA
        512MB
        7 TFT Touch Super
        Pioner Slot in DVD-RW writer
        108 Mbit Wireless Lan
        100 M Bluetooth Range
        //Power Nisse
        My Betasite -> http://haagen.se
          I have a question. How different are laptop/desktop standby's? My laptop can standby for up to a week. I imagined a car battery would have a larger capacity than my laptop battery
            Thanks ive changed from standby into hibernation now, and everything seem fine now.
              If you have discharged your battery too many times you might have killed the amount of charge it is able to hold. Also giving people jumps can hurt your battery's life too.
              ODYSSEY
              Originally posted by Tidder
              Digital-Car UK|
              (\__/)
              (")_(")
