M1-ATX Power Supply in Dell Optiplex..
  • M1-ATX Power Supply in Dell Optiplex..
    Im trying to put this new power Supply in my Dell Optiplex GX260. http://www.cartft.com/support/doku/...-ATX-manual.pdf
    (for use in car) The problem is that it needs a M/B on/off switch. I think i might have to find to wires from the control panel or? Can somebody help me here?
    P4.1,8 - 512 ram - Power: M1-ATX 6-24V DC/DC - HU: Blaupunkt Seattle MP74 - Lcd: lilliput touch. - GPS rec. Navilock NL-202U ( USB).- 2 usb for ex. - 1 cardread. 9 in 1. - Softw.: MapMonkey - Frontend: Roadrunner
    Wondering if you got any information, I am also looking to use my Optiplex GX260 in my car, and information i get i will also provide you.
    Dell Optiplex GX260- 7" Avatar Touchscreen- OPUS 150W power supply
      what does the switch on the front of the computer connect to? connect it to that.
        Cool, then we can help each other
        I started this thread at the HardwareBanter.com: http://www.computerbanter.com/showth...521#post453521
        Hoping to try that!!! Or?
        Btw. the Optiplex is cool for autopc-did use mine now for a year with an inverter..no probs.
          It just gives power on to the MB.. Like an inpuls. (brigde)
            so connect the jumper on the M1-ATX to where the power switch used to go
              hmmmm, I just found out that the power connector on the optiplex, the wiring is different from that of a normal 20 pin power connector, are you aware of that?? I wasnt.
                so use a multimeter, figure out the pinout, and make an adapter
                  Sure, if it works like an on/off switch. I dont know!!!!
                    Yes.. There is an extra 12v for the MB..and it is a double 12v-dont know why!! We have to make an adapter.
                    The biggest problem is how to make a plug so we can take the pc out and use it normal-for updating aso.. Did you think about that?? Now I use an inverter so i can still connect it to "normal" power in my house. So here we have another problem...
                      Well I wasnt worried about using it in anything other than the car, as I have another desktop and two other laptops. What I would suggect though is not making the m1 popwer supply permanantly attached to the case, as the exsting power supply slips in and out easily, thats what I could suggest as far as that goes.
                      Do you have the pinouts for the power connector on the monther board??
                      Also the M1 that that supply enough wattage the factory installed power supply gives 160W where as the M1 supplies 90W
                        Just found this stuff. Might help us make the adapter. http://xtronics.com/reference/atx_pinout.htm
                        http://pinouts.ru/data/dell_atxpower_pinout.shtml
                          hmmm it seems looking at these that the power connector on the gx260 may be a normal ATX connector, I have been reading that dell hasnt been using proprietary connectors any more, any ideas??
                            You have to find the pins on the wires from the swith, you will find them together with the Jack and usb in the front.
                            http://support.dell.com/support/edoc...nl.htm#1099573
                              The 20 pins are ok. We have to make xtra 12v power for MB.
