Shuttle G5 1100h and Opus Power Supply
  • Shuttle G5 1100h and Opus Power Supply
    So, I want to get the Shuttle G5 1100h, which is a Pentium M powered Shuttle (same basic form factor as the rest of the Shuttles. Logical solution to the power supply would be the Shuttle XPC 150 watt power supply from Opus, a high quality (from everything I have read on the board) power supply.
    Seems to make sense.
    And then, I read more on the specs of the G5 1100h, and it appears to use a power brick style external power supply. 200 watts, so with the P-M, a 150 watt Opus would work just fine, but looking at the pictures of the connection from the external power supply to to case, it looks rather proprietary.
    So, since search has turned up nothing, does anyone know anything about this, whether it is feasible or not? I would prefer to go with something that mounts inside the case, but I could easily make a mount outside the case as well, for a quality Opus supply of something along those lines.
    A link to the specs for the Shuttle G5 1100h is here: http://sys.us.shuttle.com/G5_1100.aspx
    Thanks for any help
    Dave
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
    So long as the motherboard has an ATX connection, and the Opus can power your components, you shouldn't have a problem. It doesn't matter what the connection is on the stock PSU as that won't be used anyway.
      Well, thats the thing, I don't know if the motherboard has an ATX connection,a s it is a proprietary Shuttle motherboard. I haven't been able to figure it out from the specs on the website.
      Dave
      Core Duo CarPC
      CarDomain page
        Ah, here's the specs for the MB
        G5 1100 motherboard:
        o Pentium M (socket 479)
        o Intel 915GM + ICH6M chipset
        o PCI Express Interface
        o Intel Graphics Media Accelerator 900
        o Sound Blaster Live! 24-bit EAX HD 7.1 channel audio
        o Serial ATA
        o DDR2 400/533
        o Mini PCI port
        Still no help there.
        Dave
        Core Duo CarPC
        CarDomain page
          It's also known as the SD11G5. Link to manual
          And no, it does not have an ATX power connector on the motherboard. It looks like a proprietary connector. They're calling it ETX.
          How about the Wiki?
            bah.
            I wonder if the Opus power supply would put out the right power leads that I culd cut and splice.
            A curse on all proprietary ****!
            Thanks for the info, anyhow.
            Dave
            Core Duo CarPC
            CarDomain page
              Or you could save yourself some hassle and all this research and go with a different bare-bones system
                Bah. It has all the features I want...except that power supply problem. Also looking at one of the Monarch Butterfly systems.
                Dave
                Core Duo CarPC
                CarDomain page
                  Would be nice, wouldn't it? I would probably go with an inverter. That is the lazyman's carPC. Too bad it has the problem like most new Shuttle cases - no PCI slots.
                  Audio: 4 * Rainbow Audio Germs + Infinity Basslink / Case: iStarUSA S3 / CPU: C2D P8700 / MB: Jetway NC64-LF / SC: ASUS Xonar Essence STX / RAM: Crucial 2x1GB 1066MHz / HD: MTRON 2.5" 30GB / DVD: Panasonic UJ-815B / PSU: Opus 180w / LCD: Xenarc 700TSV
                    No, no inverter for me. Too many hassles. Anyways, I found my solution:
                    http://www.mp3car.com/vbulletin/showthread.php?t=63636
                    The mini-ITX motherboard listed int hat thread, and OPUS case and power supply, and various other components, including a 2.26 GHz Pentium M.
                    Dave
                    Core Duo CarPC
                    CarDomain page
