power and ground question
  • power and ground question
    I cut off the cig adapter for my inverter because i am going to hardwire it. which is generally the power and ground. one with white stripe or solid black.
    solid black is typically ground, though as with anything, DIAYOR (do it at your own risk)
      it can be either one.... check for continuity from the center pin of the plug you cut off, whichever has continuity to the center pin off the plug you cut off will be power
      if you through out the plug then you'l have to open the unit to figure it out
