Vehicle Point Of Load in my car?
  • Vehicle Point Of Load in my car?
    I have bought the Vehicle Point Of Load DC-DC Converter. But I'm woundering.. Doesn't it work in my car with my lilliput touchscreen?
    I read in the specs that "the input voltage must be greather than the output voltage". That means that I can't use it with my battery(12volt) to my lilliput touchscreen(12volt)?
    Note: My english-skills aren't the best...
    .....what model did you get?
    is it the 5v?......
    PC Components:
    My work log
      it's this one:
      http://www.mp3car.com/store/product_...roducts_id=138
        if you cant use it you wanna sell it? i can use it for my slot load dvd.
        i got dat ***** sittin on 22s! SUPERMAN EDITION!
          I'm currently using one for my dvd-rom. The trick to it is that your car battery can be 13volts but its normally not a constant 13volts, therefore the psu will work until it drops to 12 volts or below and then the screen will turn off.
          "Dude, you could like watch porn and drive at the same time with that thing."
            Doesn't the dvd-rom require 12v to?
            EsKALad I keep it anyway.. it might come in handy.
            Edit: From where do you power your screens? From the power supplies? Can a opus 150W "feed" both a pc and a screen?
            Someone who power it from the cigarette-output?
              A DVD Rom requires 5V.
              Power the screen from the MB 12V rail.
              On the Xenarcs you can power the screen from the cars 12V, But I use the cig adaptor with it.
              AtmosUSA.biz, E-Cig Mods
              "A great smoking alternative"
