Power supply Problem
  • Power supply Problem
    I am working with a Rhycom 600watt 115v power supply being powered by a 750watt Power inverter. They The problem is i can't get it to power on at all. I have tested the power inverter with two other power supplies. One being the exact same type power supply and getting nothing, the other being an older power supply and powers fine.
    The other strange thing is that when i plug the Rhycom power supply in and you tuch any bare mettal (a screw, the case is painted) you can feal a small buzz.
    Has anyone else had any problems with a setup like this?
    And what about a ground, do you think i should ground the power supply box to the truck?, i'm not useing a metal case to mount anything.
    Anthony
    xgromx@mindbreaking.com
    2001 Dodge Dakota ClubCab
    Running MediaCar
    Commell LV-670
    P4 1.6Ghz
    Corsair 512Mb
    60Gig 7200rpm 133
    Linksys PCI Wireless with External Anttena
    8" Touch
    Microsoft USB GPS Reciever
    Audiobahn 600w 4ch Amp
    what is the older power supply? lower wattage i am guessing
    and why do you need to use a 600 watt power supply
    i would ground the power supply but would lower the wattage
    http://www.customcarcomputers.co.uk
      Break the ground prong off of the power cable you are using between the inverter and power supply.
        I found the problem, The power inverter that i am useing is only rated for 110v and is putting out 112v. The power supply needs a 115v input. I have tried other inverters and it has worked fine.
        Weird
        Running MediaCar
        Commell LV-670
        P4 1.6Ghz
        Corsair 512Mb
        60Gig 7200rpm 133
        8" Touch
          That's not the problem.
            I went and got a 120v power invertor today and it works. The power supply makes a light arkeing noice inside of it when its pluged into the power inverter though
            Running MediaCar
            Commell LV-670
            P4 1.6Ghz
            Corsair 512Mb
            60Gig 7200rpm 133
            8" Touch
              Not everyone around here knows what they're talking about, but some of us do. If you come in search of help, pay attention when it is offered.
              If the inverter worked with one power supply, then the inverter was probably fine. Did you break off the ground prong yet? I can't guarantee that it will fix your problem, but you do need to do it one way or the other.
                I had to replace my inverter and the pc will only power on when i remove the ground prong.
                Is it safe to run without the ground???
                the inverter is grounded well right now
                10 acura TL tech
                10 BMW S1000RR
                  If your psu havn't power factor correction , it's will not work with your inverter! Withot PFC peak power can be about 1000-1500w .....
                  400Watt CarPC power supply for powerfull systems- thaks for Beta testers- it was perfect.
                  Remember - AMD Athlon XP (socket A) powers from 5v rail in most times !
