Here's the power requirements for the FV24
  • Here's the power requirements for the FV24
    Just in case anyone needs these, I measured them with my voltmeter. These are all at 100% cpu usage with a celeron 900.
    12V - 0.14A
    5V - 4A
    3.3V - 1.9A
    [ 02-10-2002: Message edited by: Arby ]
    www.arbybean.com
    Which adds up to a whopping 30W, or ~3A on the car's 12V line. (assuming inefficiency of the power supply)
    www.arbybean.com
      Originally posted by Arby:
      <STRONG>
      12V - 0.14A
      5V - 4A
      3.3V - 1.9A
      </STRONG>
      .14 amps on the 12 volts is your cpu fan.
      It is a lot less with a celeron 600 or 566
      Jeff
      MPEGBOX - Plexiglass Computer
      www.mpegbox.com
        i wanna get one of these with a via c3 933mhz, no fan and uses less power also, although id still have a couple case fans
          Have you read up on the performance of the C3?
          their 900 mhz chip performes about the same as a celeron 300.
          go look at benchmarks before you buy one!
          www.arbybean.com
            <STRONG>Have you read up on the performance of the C3?
            go look at benchmarks before you buy one!</STRONG>
            lol....so why did they even call it a 900mhz when it is missing 600mhz... this is too funny
            abcd-1
              I've been speaking to a guy at via - they are making a new board. Don't know if n e one has heard about it but its a mini itx format board - about 17cm by 17cm and has all the features of the fv24 plus a bit. The bummer is it has a built in cyrix chip, but its very low on power consumption and performs reasonably well - it will watch a dvd or do gps navigation without a problem. What it won't do is play doom 3 at 1024 x 768, but if you don't want your car pc to play games then perhaps this board would be a good one?? The C3 is also cheap and cool - it can (not officially) be run without a heat sink! Think what you will but this isn't a bad processor if you want a car pc plus its cheap!!
              Mediabox Hardware Project
              Current Stage: A complete redesign, although not much happening right now!
              Mediabox Software Project
              Status: Writing Sync Software (still) and playing around with interface
              To do: Far too much!
