newbe and almost finish
  • newbe and almost finish
    hi i am new at this can some one post a diagram of the electrical wireing for a carputer i have the power inverter and the PSU do i need something else?
    this is done and my carputer is finish!!!!!
    i am sorry i bet there is a thred already about this but i didnt find it
    [ 02-12-2002: Message edited by: kris3 ]
    carputer:
    P2- 266 mmx
    94 ram
    WD 9 Gigas
    ATI AIW
    on SUBARU IMPREZA 2000
    I personally wouldn't consider using an inverter as being finished, as this is a cheats way, but thats just my opinion,.. Do you have any pics???
    2 week temp ban (spam and complaining about deleted posts)
    register another account and you're gone for good.
      soon i will post pics when finish i just tested the carputer and worked great. now i need some case ajustments and i think is done. but if any one has a sugestion, always welcome.
      carputer:
      P2- 266 mmx
      94 ram
      WD 9 Gigas
      ATI AIW
        Hey kris3, congrats on your system.
        Don't listen to THEMP3KID, using an inverter is fine for 70% of the people out there.
        To wire up your inverter, it would be best to run a wire directly from your battery to power it. Then you could either set up a relay off the acc line of your car (so the inverter turns on and off with the accessories line of your car) or mount a switch in the line, to manually turn the inverter on and off.
        Both setups have there pros and cons, its just down to your personal prefference
        http://www.mp3vl.tk Plans and progress on my install - (Updated 28 June 02)
        Australian mp3car Portal
        mp3car related links Check them out / Add some
        mp3car FAQ - RTFF
        [########==]80% Assembling
        -=Current Progress: Working Sproggy supply, building box.=-
          thankz i just did exactly the same u told and is working great!!! now some cosmetic adjustmen
          carputer:
          P2- 266 mmx
          94 ram
          WD 9 Gigas
          ATI AIW
            carputer is done just some problems with the lighter plug that i wired to the trunk. Seems like it the fem of the plug is a bit larger than the inverter plug and it loose and turns off my pc when the car bounce. I was thinking to make a solering point at the tip of the plug so it wont get loose.
            carputer:
            P2- 266 mmx
            94 ram
            WD 9 Gigas
            ATI AIW
              Y do you guys think mp3Kid is wrong. take it from me and prolly from him. Sure your inverter works fine now, i guarantee you that down the road, you will start to experience strange things... it might now happen right away, but once the signs start showing up, it will **** u off
              abcd-1
                what kind of things could happen??
                tell me, tell me !!!
                carputer:
                P2- 266 mmx
                94 ram
                WD 9 Gigas
                ATI AIW
                  hey kris why do u want to play with AC power in a car .. after all you just require DC power unless ur planing to put a microwave or other home appliance in your car ..??
                  Think Ac current in your car just a case of badluck and the AC current runs through your cars body .......! BOOm ! you will see 4th of July a bit too earlier..
                  Advice inverter is NOT good!....
                  Mastero
                    ok then what options do i have remember i am a newbe...
                    carputer:
                    P2- 266 mmx
                    94 ram
                    WD 9 Gigas
                    ATI AIW
                      Hey Kris3,
                      I'll side with Hornet on this one, if you already have an inverter, try it out. I've been using the same $35 inverter for a few years now (constant use, if my truck is running, the inverter is on) and have never had a problem. While a DC-DC psu may be the ideal way to go, there are quite a few people here who would not consider using an inverter as "cheats".
                      97 Dodge Ram 13.8" touchscreen/DVD/GPS/TV/FM
                      Some pics & details here
                        cool i will still use my jensen 300w inverter then
                        BTW great job on your pick-up
                        carputer:
                        P2- 266 mmx
                        94 ram
                        WD 9 Gigas
                        ATI AIW
                          There is no right or wrong way to do it (to a point) and really there is no better power supply to use, inverter or DC-DC, its all boils down the the person doing the install, there electronic capabilities, their funds, and what they are trying to achive.
                          I couldn't see the point in running a DC-DC if your system was going to spend half its life inside hooked up to the hi-fi for parties, I know i for one dont have a 240vac to 12vdc power supply to be able to run it.
                          For some one who can't build their own dc-dc supply, the quickest, easiest and cheapest alternative to get tunes pumping in their cat is to use an inverter
                          mp3car FAQ - RTFF
                            there must be a thred about the diagram of a dc-dc PS, were can i get it??
                            carputer:
                            P2- 266 mmx
                            94 ram
                            WD 9 Gigas
                            ATI AIW
                              Hop on over to sproggy's website for information and diagrams on a dc-dc psu. Parts list, PCB layout etc can be found here. Mastero sells the PCB's and even kits to build these.
                              mp3car FAQ - RTFF
