power to laptop and 3 mobile devices
  • power to laptop and 3 mobile devices
    I have too many devices in my car!
    I have a nokia 3650 phone, dell laptop, motorola handsfree, and 7290blackberry. I use all these devices daily for my job.
    I am getting sick of swapping the lighter adapters to charge up my cell phone/berry. And leaving my car to plug in my laptop.
    How can I make it so that each of these has a "permanent" way to be charged/mounted? I would like a custom built rack for mounting all these devices and keeping them charged. I suppose the laptop would be hard to mount but are there any solutions? I would like the laptop mounted near passenger seat ideally.
    2003 Honda Civic Hybrid, Dell Mini 9 with OSX Leopard (64 GB SSD Runcore), Ram-Mount laptop mount, Cradlepoint MBR1000 3G hotspot, Jensen VM9312, Garmin C340 GPS
    well you could use a Carnetix 1290 if the dell isnt one of the new models with proprietary connectors.
    Otherwise i would hard wire everything to a multiple cigarette lighter adapter mounted below the seat. Leave it hot at all times. Get yourself a battery saver that cuts power to the car if voltage drops to a specified point.
    I'd run the Dell off of the 1290 so it could incorporate shut down controlling and hardwire everything else
    Take my advice: Do not try to build a system that includes EVERY feature. Start with the basics, build it to a bug free state, and THEN add on.
      Why not add more power ports? My s10 had a divider in the door pockets that was like 1.5" wide so I drilled a hole in it and stuck another 12v plug there then plugged the cell phone charger in there and dropped it in the door pocket. Then I put one on the back of each seat for stuff I would throw in the back of the cab or stuff I would sit on the seat, made it neater than having the cords stretched from the dash to the seat. Doing the same in my new truck http://www.ninefamily.com/Projects/T... - 320x240.jpg This is behind the front seats
        Well, you put quotes around permanent, so what do you mean by permanent. And Mount? So, you want to power/charge everything while it is mounted somewhere. In reach from the drivers seat? What kinda car? Do you have a hummer? Do you take passengers with you? Are you currently
        There are SOOOO many options for power. You can add one of these http://www.cell-phones1.com/accessor..._splitter.html, though you should be carefull how much power you draw through everything.
        Your laptop can be charged with one of these
        http://www.dealtime.com/xPC-Targus_U...apter_for_Dell
        For your laptop, you can get one of these http://www.jottodesk.net/, or one of the RAM MOUNTS from here http://www.ram-mount.com/ramgps.htm or http://www.expressmounts.com/. Notice also that RAM makes mounts for almost EVERYTHING you might want to mount in your car.
        Michael
          thx guys for all your suggestions. That ram-mount place has everything, I am even more confused with all the possibilities now
          just how many of the cigarette lighter splitters can I daisy chain onto each other? would a laptop , blackberry, and bluetooth hands-free be too much (4 devices)? If it is too much, what do I have to do? Run a wire directly to the fusebox?
            The amount you plug in all depends on the current they pull. Find the fuse for your plugs and see how many A it is. Then take all the devices you have and add them up, if its less than the fuse for the plug then your safe.
