m1 or p1900??
  • m1 or p1900??
    ok, what should i do?
    i have this case - Travla Mini-ITX C138 Aluminium Case with 120W PSU
    now i was planning to buy the M1-ATX 90Wbut i have been told the Carnetix CNX-P1900 140W Dual Output Power Regulator would be better. I no that the p1900 has alot more power but is it a better option ??
    cheerz
    Nem
    YOu already have power supply. The Carnetix is designed to work with the power supply you already have.
    The M1 is a replacement for what you already have.
    Understand that the Carnetix only regulates the power from the battery (which will fluctuate) to provide a constant voltage to a device that requires it, like the PSU in your Travala.
    How about the Wiki?
      yar i no the carnetix is a regulator but which is the better way of doing things, psu and regulator or new psu ??
        NemesiS153,
        Hmm....I kinda like the P1900 myself.....
        Seriously, what processor are you running in your C138? If it's a P4 you may be better off with the P1900. Just my 2 cents....
        MikeH
          heres my rig
          Via Epia M10000 Motherboard
          512 pc2700 ram
          60 gig 2.5 HDD
          slim line dvd/cdrw
          linitx plus touchscreen
          bu-303 gps
            Yeah, but you're more than a little biased.
            How about the Wiki?
