m1-atx not working?
  • m1-atx not working?
    Yes I know this is kind of redundant but ....
    mini-itx (sp8000)
    no periphals (just testing for now)
    no usb devices or dvd so the power requirements are simple mobo
    Now here is the voltmeter:
    Red (+) solid 12V when car is on or off
    Ignition (sw) gets 12v when car is on
    Gnd is good
    With the molex plugged in, the m1-atx does nothing ever. I cannot get the pc to start up.
    I can validate the power by checking the inputs on the m1-atx (touching the +|sw|- input connectors), and they confirm good power (by touching the underside of the red/white/black connectors). But the whole right side shows nothing: J6 shows nothing, J8 nothing, and the LED notta. I tried manually tripping the starter on the mobo and by using J8 but either way gives me notta.
    How could I confirm my m1-atx is toast before shipping it back?
    I don't see any burned up sections, the chip looks fine.
    Any ideas to try out lemme know... So close but so far away yet again :/
    Ok better...
    Ok something is up with my jumpers, once I removed them and connected it in dumb mode it booted up fine.
    So I will experiment with some jumper settings, anyone have a fav jumper setting to use?
    Be specific on which jumper is on|off.
      Did you put that 4" red/black wire from J6 to the MoBo power jumper? I had your same problem until I figured that part out...
      Color Code:
        i made the same mistake..
        whatever end you had the jumpers on .. move it to the other end .. all I got to happen was the fans twitch, look closely at the manual for where pin 1 is
        Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
