The power-off delay circuit
  • The power-off delay circuit
    I was planning one building this circuit ( http://www.astron.nl/~smirnov/poweroff.html ) to kill the power if I forget to shutdown or cut power one day. The only problem is, I noticed that when my key is in acc my computer runs fine. Then when I go to start my car, the voltage drops and causes the pc to reboot. So I might run into a problem here, what do ya think? Anyone else have this occur to them?
    [ 08-09-2001: Message edited by: Carlos C ]
    My Install Thread
    digitaljetta.com
    MKIV VW Jetta
    How do I get sound to my car?
    carlos, I don't think you can do much about this unless you got an aux battery. i have had varied results with this. Usually when the comp has been running off the battery for over 15 minutes and i start the car, the voltage will drop too much to keep my psu going, but if its been on for only a short amount of time and i start the car it seems to work fine. maybe you could do some more tests and see what results you have?
    Athlon 500, 128 MB, ATI Xpert 4MB AGP TV-Out, Sound Blaster Live! Value, 8.4 GB, 2x20 Backlit LCD, Keypower 250 Watt ATX DC-DC, DSchmitd Startup/Shutdown Controller, IRMan + Backlit IR Remote, Custom Keypad, 5.6" NTSC LCD, In-Dash Slot Loading DVD, all installed in an '87 Honda Accord LX-i
      A second battery will help. A DC-DC will probably solve the problem, for about the same price as a second battery.
        Considering it's $30 for a battery isolator and $30-40ish for a battery Aaron is correct
