power? Subs w/ amp
  • power? Subs w/ amp
    i was wanting some info if anyone has used the same power cable to their amp as the power source for the computer and how well it works
    Case built and working
    Amptron 586 motherboard onboard snd/vid/lan (purchased)
    200mmx processor (already have)
    5g harddrive (already have)
    Two 4x40 lcds (future)
    I am powering 2 amps and 1 amplified bazooka sub and my computer with the same power line ( 4Gauge from battery)
    Everything works beautifully. But it all depends on your setup...
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
      How did you split the wire into those 4 components?
      theMP3RUNNER
      car|'93 4runner 3.0l v6, aiwa cdc-x317 head unit with aux-in
      carputer|pentium 133mhz, 40mb ram, 7.24gb hard drive, system blower pci/isa fan, 800w peak ac inverter, 40x4 backlit lcd
        you use a distribution block. You split one 4gauge into four 8 gauge. Likewise you do the same with the ground wires as well so everything becomes grounded to one point minimizing ground loops.
        My TL CarPC ver2
          more importantly, how the hell did you isolate the computer enough so that the drilling of the sub doesn't shake your hard drive to bits?? =)
          I too have a nice rack of subs (2x10" and 1x12") and I'm worried about what'll happen to the poor computer =)
          IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
