dc - ac power inverter
  • dc - ac power inverter
    Hey all,
    what's the best DC - AC power inverter and where can I buy it?
    I've heard that some DC -AC inverters will cause noise and flicker. My other question would be if I get an inverter with noise would I be able to connect an ITPS regulator to regulate the voltage? I'm understanding that the reving or the change in voltage cause noise... Not sure if I'm correct.
    and yes I did ...
    My Car!
    http://www.voltageconverters.com/pur...inverters.html
    rebuilding carpc... kinda..
      ok that answers the inverter part....but puting an ITPS regulator before the battery do anything?
      Battery + ITPS regulator + DC-AC power inverter
      My Car!
        "Input voltage range 10-15 VDC"
        cranking brings the car down to 7-10 volts, normally, so if you want to be able to survive crank, and your ITPS can handle it, sure.
        or you can search for tank circuits here to keep the voltage up during crank
