My Arise ACE865 is DEAD
  • My Arise ACE865 is DEAD
    Just to let people know, what I originally thought was a HD problem is a power supply problem. I got my new HD and installed it, but it exhibited the same behaviour as the old one (see topic in General Hardware). Unfortunately, my DC-DC is out of warrenty, so I must buy a new one.
    Just a general caution, weird HD problems may be attributed to a dying DC-DC converter.
    I've also experienced strange Windows errors due to a malfunctioning power supply. If anyone keeps getting Protection Fault or memory errors, try using a different power supply; it may just solve the problem.
    Aaron: So is your original HDD still alive then, or did the failing PSU kill it?
    Jason Johnson
    Yorba Linda, California
    http://www.m2pc.com
    MPC Phase IV - *** PENDING ***
      I don't know if the original HD is still good, as it was returned to Fujitsu on warrenty. I would sort of feel bad if it was good, but I have given Fujitsu quite a bit of business over the years, so I think they'r profits from me will more than cover a replacement drive.
        Don't laptop hard drives run off of the 5 volt line? If so, I can't help but wonder if the extra power draw on the 865's 5v line caused its pre-mature death.
        [ 09-05-2001: Message edited by: bh76 ]
        http://thecoldfront.com
          The HD does run on 5V, but at only about 150mA, hardly enough to make any difference. I just think I got a bad supply....It would certainly be in line with the rest of my luck.
            Make yourself a DC-DC supply..
              Hey, Aaron - Something you may want to check... When I got my DC power supply, it had a loose cap inside. I guess from being kicked around in shipping??? Due to the mobile environment, you may wish to re-check all the components. Maybe something just jarred loose???
              ~m
              PII 266, 512 MB RAM, 10 Gig, 36x CD-ROM, 16x DVD, DeLorme GPS, 5.6" LCD Screen, Dschmidt power controller, Keypower ATX DC-DC Supply, PowerAmp Macro controller, Dauphin mini-Kbd.
              Sony Head Unit, Sony Unilink input selector, rear deck Kenwood 6x9's, stock door spkrs... All in my '96 Civic, of course :}
              BC ROCKS!!!
                aaron, if u r lucky, it might just be the 5v part os your psu that is knackard.... test it...
                if it is just 5v that is the prob, then use a max787 based circuit to get 5v and use 2 psu's 2gether
                btw.... the max787 circuit is easy to make, it`s onlt 5 or 6 components, just remember to heatsink the max787...
                hope u understand what i mean
                My Setup
                  no....where are ur pics
                  abcd-1
                    charles, what i'm saying is that just the 5v part of the arise might be the problem.... since it was only the 5v hd playing up at first
                    and if this is the case, then fixing it will be cheap and easy, by making a 5v dc-dc supply
                    my pics & website are coming soon btw, it`s just that my car is off the road at the moment, and im really busy getting ready for university at the moment
                    My Setup
                      I received the new supply in the mail today (ordered it on Thursday) so I will see about installing it tonight or something. It doesn't seem to be worth my time to try to repair the supply I have considering the price of a new supply (with warrantee) and the aggrivation a flaky older supply would cause...
                        good point...
                        i`d keep the old one though, it might come in useful for spares
                        My Setup
                          Well I installed the new supply, and all is once again right with the world. Cruised down my street at 12AM cranking Enigma - Push The Limit. Really impressed the neighbours.
                          I still have the old supply, and I will hold onto it in the off chance that I will put another computer in another car. I'll fix it at some point when I get bored...
                            Aaron -
                            Did you ever find out what exactly went bad in your old supply? This might be good to know for those who have the same supply...
                            Jason Johnson
                            http://www.m2pc.com
                              I have not looked at it in detail yet, but I would imagine that the +5V became intermittant and/or deregulated. When I have time, I will load test the supply and figure out what's wrong.
