opus power up then turn off right away.
  • opus power up then turn off right away.
    when i turn on my car the opus 90watt would do the 10sec wait to boot up but once it boot it shut off rite away. then i have to pull the fuse out and unplug the connector off the opus. then the green light would start bleeping again. but when it go to boot up the mobo it would shut off again. the green led would blink once ever so seconds. before all this happend i had my car jumped. it blew the fuse on the opus. could the opus be done for? thanks
    it worked fine with the same setup before the car got jumped? you did not add any hardware or usb devices?
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
      yeah it worked fine before then. i just got the car back from the dealer today. due to the transponder on the keys got deactivated. before the car die everything worked fine. i did try to jump the car the day it died
        most likely the problem, I would check it with a multimeter and see what happens if you disconnect all usb and other unneccassary items. But it does not sound good.
        My Install
        Software:
        CFiG v1
        CarShell
        StopWatch
          so you think it mostly the opus is the problem?
            not sure, but it sound like it might have taken a hit. try the opus not attached to the computer and try the computer insde with a AC-Dc power supply if you can. Good luck
            My Install
            Software:
            CFiG v1
            CarShell
            StopWatch
              thank you
