sproggy powersupply
  • sproggy powersupply
    Just a quick question... uhm well...
    Can anybody tell me if sproggies PSU wil have enough power to run a MB + athlon tb 850 + gforce 2mx tvout + philips accoustic edge + 40Gb maxtor?
    And if not, does anybody know how to make/ where to get a powersupply that will do the job?
    Cheers!
    If at first you don't succeed.........
    destroy all evidence you tried
    for info on t6369c LCD or Presslab's powersupply check:
    http://www.namms.tk <=updated!!
    no, you will need a 250watt supply
    http://www.keypower.com/DC_power/DX-250H.htm
    KP-DX 200Q (12V DC -&gt; 200watt AT) $121
    KP-DX 250H (12V DC -&gt; 250watt ATX) $164
      thanx for your comment bgoodman, but $165 doesn't fit in my budget, could you tell what can be powered with sproggies PSU (cahnging only the MB & proc)?
        lol...get an arise psu. It will solve all your problems and maybe future onces. I hope your mb is AT style.
        abcd-1
          I built sproggy's power supply. The problem you will have with it powering that much stuff because it has trouble supplying enough 12V current. I'm working on a modification to help this out using the MAX1771. I also made a bit of a mod to up the 5V current. Basically ran two MAX787's in parallel... I'll have pictures posted soon.
          j
          j's MP3Car.com Web Site
          [######----] 60% complete (1st try)
            Maybe I also could do something like that
            Using 2 MAX787 and 2 MAX788 will supply more than enough power vor the 5v and 3.3v
            Have to search for something that can handle like [email protected] (and then maybe use 2 of them ??)
            Q:
            Do computers use more than 5a @ 3.3v
            (I'm guess it's only needed for memory and processor, but do they use so much power?)
            (I ask this because I have 2*MAX788 and 4*MAX787 and when the computers don't use too much current at 3.3v, than I maybe could use the other parts for a second power-supply, cause I don't think I will only build one... girlfriend already likes the Idea and also wants one )
            Greetz
            Raas - The Netherlands
            ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
            GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
              I'm wondering....
              after looking hard at sproggies schematic, it seems pretty easy to get +5V @ 10A , +3.3V@ 10A,
              only problem is the 12V part, I cant figure out why the max. current is so low, I checked national's website and it says that the max current is 5A, so is the T6 the problem? I don't get it...
              Cheers!
                The power supply I'm building will supply 2 amps at 12 volts. (that is with an 8-14 volt input.)
                If you want to make sure that your input won't go below 11 volts, it will supply 3 amps.
                If you make sure it won't go below 12 volts, it will supply 3.3 amps.
                I just tested it for 5 minutes drawing 3.5 amps with a 12 volt input and it worked just fine.
                Jeff_
                MPEGBOX - Plexiglass Computer
                www.mpegbox.com
