question regarding DC/DC supply
  • question regarding DC/DC supply
    Okay guys, I am working on the DC/DC supply for my carputer and had a few questions and wanted a few opinions regarding what i'm using.
    Just for a little background, my system does not need negative voltages for anything (my sbc generates them onboard i think).
    For 5V, I am using an Astec power module that accepts 9-36V DC and adapts it down to 5V at up to (a theoretical) 3A.
    see below link for a pic of the module. http://www.geocities.com/mp3lantra/power.html
    12V is where things may get a little tricky for me. I dont need all that much to run the hard drives or mainboard, but my 10" VGA LCD runs off 12V @ 2A and I would like to run it off of the same supply unit (if possible). My question is, are there any regulators (cheap *** linears only do 1A if i recall) beefy enough to give me the 2-3A I need?
    I also am thinking that I would need some sort of crowbar or tank circuit (I've seen some that use a 50mH inductor and a 2200uF capacitor) to protect from startup voltages and to smooth out the input. What are your thoughts on this?
    Thanks for any help that can be provided.
    -Lee
    There are several 12V linear regulators rated from 1-5A. Search the National Semiconductor site and you should find them. You will need to use a "low dropout" variety. You shouldn't need any filtering, except for a few capacitors at the input and output of the regulator.
      If you need the current, have a look at the LM2576 voltage "regulators" they'll put out 3amps. I know someone who's used them before and had no problems, and 4 external component's makes them pretty simple.
      Hope that helps.
      Rob
      And you say people actually pay money for M$ Windows?
      www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
      Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
        Hey buddy .. i know the exact regulator you can use .. its called LM1084 from national it come in 5, 12, 3.3 its rated 5amps
        Very cool chip !:-) got 10 of them
        Mastero
          Originally posted by mastero:
          <STRONG>Hey buddy .. i know the exact regulator you can use .. its called LM1084 from national it come in 5, 12, 3.3 its rated 5amps
          Mastero</STRONG>
          They don't work, for some reason, not happy with a 14volt input, the 12volt ones that is, they won't regulate right..
