sproggy power supply drill bit size?
  • sproggy power supply drill bit size?
    what size drill bit should I use to make the sproggy 2.5 power supply? thanks in advance
    You will probably need different sizes for different components, or, you could probably just use a 1 millimeter for all the holes..
      I suggets you first drill all holes with 1mm drill,and if the component doesn't fit,extend it with 2 mm drill.If I remember correct,1 mm for resistors and capacitors,2 mm for all the rest.
      Enjoint life!
