Which Coil?
  • Which Coil?
    Hi, I'm trying to build a Sproggy MK2.6, and I can't figure out which piece to order for the "T6"
    on the Part List PDF, is says :
    T6 (Q4339-B) ----- Part Number: Q4338-B
    okay, so there's a slight difference in the two numbers one having a "8-B" suffix while the other has a "9-B" suffix.
    On the coilcraft website, they mention both the Q4339-B and the Q4338-B as ones that they connot sample because of "hobbyist building mp3 players".
    the spec sheets for these are WAY different, so which is the right one to buy???
    this one:
    http://www.coilcraft.com/q4339.html
    or this one:
    http://www.coilcraft.com/q4338.html
    Thanks a lot,
    -Miles
    Near Completion: Intel P166 MMX, 32MB ram, 13GB Hard Drive, Keypad, 4x40 LCD. Sproggy MK2.6 ATX PSU. Win98SE with Winamp and Mark Zehnder Plugin. (Web-site: very soon)
    hi I can't remember which one you should use, but you can check the older designs to see which is the correct one.....
    If at first you don't succeed.........
    destroy all evidence you tried
    for info on t6369c LCD or Presslab's powersupply check:
    http://www.namms.tk <=updated!!
      Thanks a lot... BTW, it's the Q4339-B for anyone who's interested
      -Miles
