wiring 528T timer
  • wiring 528T timer
    Hey
    i bought a 528T to keep my 1 atx (havnt got it yet) running for 90 seconds after IGN off, to allow laptop (on seperate PSU) time to hibernate and still access drives and accessories.
    The wires are:
    Orange 87A: NC
    Brown 87: NO
    Yellow 30: Common
    B&W: Trigger
    Black: Ground
    Red: 12VDC ground
    Blue Loop: UNCUT - trigger upon receiving negative
    CUT - Trigger upon negative going away
    I need it to come straight on with accessories line, but wait the 90 seconds when the accesories line disapears.
    I though that
    Yelow: Power from battery
    Orange: Wire nothing
    Brown: Wire to M1atx so it closes when triggered
    BW: Accesries line to act as trigger
    black and red; 12v ground
    But when i do it like that, brown always get 12V regardless of ignition, so any ideas?
    Progress 50%
    Next Step: Making Enclosure, Hard Wiring PSU
    Thinkpad 1Ghz P3
    256MB RAM
    Lilliput Motorised
    80GB 3.5"
    If the brown and yellow are disconnected (NO), then why are you getting 12v out of the brown wire?
    It might have something to do with your trigger wire. The trigger wire might be receiving a 12V+ instead of a negative. So you can use a relay to change the signal received by the 528T to a negative.
      yeah sorry it was the orange that was always 12v
      any ideas?
      Progress 50%
      Thinkpad 1Ghz P3
      256MB RAM
      Lilliput Motorised
      80GB 3.5"
        You said that the trigger is triggered on a negative but you are sending it a 12V+ from the accessory. I don't know if that's causing any problems.
        Other than that, it looks like the way you have it hooked up currently should work. The ground (from the relay I was talking about) triggers the brown wire that is normally disconnected from the yellow to close, giving you 12V+ for as long as you set it for. After the desired amount of time the relay will go back to it's orginally state (brown wire disconnected).
          Originally posted by McGinty
          The wires are:
          Orange 87A: NC
          Brown 87: NO
          Yellow 30: Common
          B&W: Trigger
          Black: Ground
          Red: 12VDC ground
          that is wrong..... it should be: red=12vdc (+)
            yeah i just re-read and it says
            +12VDC Ground, so obviously a mistake. This should go to my battery right? and the accesories line to the trigger to switch on/off
            Cheers
            Progress 50%
            Thinkpad 1Ghz P3
            256MB RAM
            Lilliput Motorised
            80GB 3.5"
              Yeah, you got it... the red needs to be connected to a 12V+ from your battery.
                ok i have done that and it is functional, but not really how i want it to run
                Now, the orange wire has 12v when car is off
                the orange wire has 12v when car is on
                brown wire has 12v for 90 secs when car is off
                BUT i need the brown wire to have 12v when is ON and for the 90 seconds after it switches off, then have 12v to orange the rest of the time cos its not hooked up to anything.
                Alternate ways of achieving this i thought:
                Have a relay, and join the ACC and BROWN together at the relay. That way, ACC will keep it connected when car is on, BROWN will keep it connected for 90seconds after, and it wont be connected for the rest of the time. This seems plausible, but i am concerned that then it will **** with my other ACC relay which tells the laptop to hibernate when car turns off. I am thinking that with the brown giving 12v, the laptop wont hibernate till after 90sec, defeating the purpose.
                Any Ideas? I am doing the install today, so these delays are gay
                Progress 50%
                Thinkpad 1Ghz P3
                256MB RAM
                Lilliput Motorised
                80GB 3.5"
                  use a relay, have it activated with ign, & also activated with the timer.... BUT you will need to also use a diode so the timer doen't back feed the ign.... the diode should go in the ign feed....
                    ah diodes, now i remember them
                    Thank You kindly, because that feedback was what i was worried about, thanks killer-bee
                    Progress 50%
                    Thinkpad 1Ghz P3
                    256MB RAM
                    Lilliput Motorised
                    80GB 3.5"
                      working like a charm, in terms of timing, so now onto my next problem.
                      That relay was for a mi1atx, whose sole job atm is running a hdd (laptop runs of seperate dcdc supply. I have the m1atx in dumb mode, with no jumpers (as that timed relay is controlling shutdown of psu etc.etc.) but it wont run my hard drive.
                      Input is good at ~13.9v, but then the power on the rails in insufficent. With nothing hooked up, the yellow 12v line output around 8v, why would that be?
                      Im gonna do some further reading, but i want to get this in tonight and cannot think what could cause it. The output for a led is outputting 6v when the car turns on, so i know the m1atx is functional, but yeah.
                      Any help appreciated
                      Progress 50%
                      Thinkpad 1Ghz P3
                      256MB RAM
                      Lilliput Motorised
                      80GB 3.5"
                        check grounds & all connections... if you have almost 14v in & a GOOD SOLID ground, then there may be a problem with the ps itself....
                          I am using one of those timer, I found 90 seconds is not enough, I am wondering if I can modified the timer. I would say 5 mins is good. Any electronic guru here?
                            you can use a pac-tr7.... it is much more adjustable, but a little complicated to program..... get one & the instructions will tell you all you need to know..... very versital tool that pac tr-7.... it can do alot..... it is most popular as an alpine video lockout bypass module, but it can do so much more....
                              TurboCad, does pac-tr7 has a build in relay?
