M1 ATX + Centrino 1.5 Ghz + AOPEN XC CUBE MZ855
  • M1 ATX + Centrino 1.5 Ghz + AOPEN XC CUBE MZ855
    It is possible to get working the M1 ATX with my centrino or I've to buy the OPUS?
    Search these forums for POWER CALCULATOR and use it.
    You'll be able to answer your own question.
    How about the Wiki?
      Ok I think it can do the job, but I've another problem... my MB has a 4 pin plug near the cpu... and the M1 atx spec doesnt'say anything. Sorry for my poor English
        Ahhh, the 4-pin 12v connector.
        If the M1ATX doesn't have it, then it won't work.
        How about the Wiki?
          It says only 3 output connectors and no 12v connector... sigh... the opus 150W is too much expensive and the opus 120w is too big for my case. Do you have any suggestions?
