Completely disappointed/confused
  • Completely disappointed/confused
    Okay I have an old Compaq SFF Evo d510s desktop that I was gonna use for my carpc. Well I got everything installed and ready and got my touchscreen bezel made and all and bought the Opus 120 watt PSU not even thinking straight. Today when I went to wire it all in I realized the Opus which is ATX based (20 pin) will not work as the Compaq motherboard is a freaking 14 pin.
    I have searched and searched and found nothing. My question is can I rewire the plug off the Compaq PSU to make it work with the Atx standard plug on the Opus? If I can will someone kindly lead me in the right direction or point me to a thread that explains the process. I am not that electronically inclinded but I can rewire things if I know what I am looking at. Thanks.
    Looks like your not the only one...
    http://mp3car.com/vbulletin/showthre...q+power+supply
    2005 Ford Focus ST
      You sure thats enough power? Isnt that a 2ghz machine?
      2005 Ford Focus ST
        I think 120 is fine for only what I am using it for. Only DVD, 40 gig hard drive, and Frodoplayer will be used. 120 watt should be enough right?
        Thanks for linking that to me. I didn't even find that. My search ability sucks donkey balls.
          Looks like most people just go the inverter route. I again searched but no clear answers. How does an inverter work with powering up the system and gracefully bringing it down? Can it do automatic restart/shutdown?
            No. You'll need an an SDC (Startup/Shutdown Controller)
            Want to:
              The applications you're going to use have no bearing on how much power the CPU and components will draw.
              No, 120w would be enough for that system. The CPU is a P4 2.4Ghz (according to what I found on Google.. They may have different CPUs at different speeds).
              How about the Wiki?
                Yes it is a 2.4 gig P4 system. Are you saying that 120watt PSU won't be enough?
                Sorry for all the questions, this is confusing me but I am trying to learn!
                I took a look at Ashsoft's diagram but the PSU plug has two wire colors unaccounted for....a white wire with a red line, and a peach/pinkish wire. I can't find any info on the pinouts for the Compaq D510s mb to psu attachment. Grrrrr so close yet so far..........
