Temperature Chamber tests on mini-ITX boards and PSUs
  • Temperature Chamber tests on mini-ITX boards and PSUs
    I thought you might be interested in this data...
    We have a temperature test chamber where we test all our products -- the other day I did some testing on few popular mini-ITX motherboards and our M2-ATX power supply.
    Cold_start = board will turn on
    Cold_ride = start at 0C, ride temperature down
    While all = boards worked OK on the high tem rage (up to 75-85C) here is what they did on the low temp end:
    Model Cold_Start Cold_ride
    motherboard
    EPIA-5000 -30C -42C
    EPIA-M10 K -35C -42C
    EPIA-MII-10K -15C -42C
    power supply
    M1-ATX -42 -42C
    M2-ATX -42 -42C
    -42C is the lowest temp I can get with this test chamber.
    All motherboards started to freak out around 0 C when heavy condensation occured. Forced air (fan) over the motherboard removed the condesation and no more crashes occured. Please note that I obtained this heavy condesnsation by opening / closing the door several times, this kind of violent humidity fluctuations are less likely in a car and that can be easily dealt with by blowing air over the motherboard (some 40x40 mm fans)
    I did test a seagate laptop drive to -10C and then I stopped, was worried about data damage, that was a HDD with real data on it...
    -Andrei
    This is some nice info to read...Thx
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
      The tolerances for temperature shown by the hardware far exceeds the temperature range that can be survived by this driver!
      When it gets below -15C or above 75C, I would be more worried about my body parts than any hunk of electronic equipment. Ditto for debates about the G-forces that can be tolerated.
      Still, thanks for posting that information.
        What are you talking about? It was -19C here this morning and I have not seen any corpses on streets
          Must be someone talking from california. Anything below 0C is unbearable
          PowerVoice v1 | NaviVoice Source
          GammaControl v2.4
          SKINbedder v3
          1995 Lexus SC300
            Moscow and inland Russia are in a worse situation... They're looking at -31C around the 20th and 21st of this month.
            For Sale: Carputer (CarPC) & RCA Y-Adapter
            Newsflash: Take a look at my unsold stuff above, thanks!
            Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
              Good thing we don't live around that area anymore
              GammaControl v2.4
              SKINbedder v3
              1995 Lexus SC300
                we? who else do you mean?
                <I declare this thread HI-JACKED>
                  GammaControl v2.4
                  SKINbedder v3
                  1995 Lexus SC300
