30 Min Off Delay, M2-ATX?
  • 30 Min Off Delay, M2-ATX?
    Has anyone found a reliable, easy way to get around the stock timings on the M2-ATX? I looked around here and didn't see any but I wanted to ask before I go off to reinvent the wheel. All I want is a long enough initial delay to not be rebooting my system everytime I go into a gas station or post office. I'm leaning towards creating a circuit that supplys power to the signal wire for ~30 min after the car is switched off.
    So offdelay #6 doesn't work for what you want?
    30 min/never (taxi mode)
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Originally posted by bgoodman
    We're an international forum, post in whatever langauge you like.
      From what I understand that leaves the 5v rail on all the time unless the battery drops below 11 volts. I was looking for a setting with hardoff that used the 30min initial off. So a setting that was 30min/2hours, or something similiar.
        Yes. Buy a DS-ATX.
        [Hey, the right tool for the right job!]
        But on a serious note, I am also trying to figure out a way to change the timings "on-the-fly" when using the M2-ATX. So I am interested to hear any ideas you may have.
          i am very interested in this answer as well, as I'd love a 30min/2hour setting also....
          Originally posted by piabu
          Yes. Buy a DS-ATX.
          Normally i'd agree with this, but it's more than twice the price, AND doesn't fit into my Morex Case
            I saw another post that said all these options are available, but some are not listed in the manual (haven't tested them though). There's a 10min/1hr and a 15min/2hr - not quite the 30min you're looking for but enough to get you through a quick stop.
            ABCD OFFDELAY / HARDOFF
            0000 standard PSU
            1000 5 seconds / 1 minute
            0100 5 seconds / 2 hours
            1100 5 seconds / never
            0010 30 seconds / 2 hours
            1010 30 seconds / never
            0110 30 minutes / never
            1110 3 hours / never
            0001 10 minutes / 1 hour
            1001 15 minutes / 2 hours
            0101 1 hour / 1 hour 15 minutes
            1101 5 seconds / 2 hours (SureStop)
            See my install here:
            540i / 320i Mods
            Get a free and lightweight blog here
            iPhone Hacks
            Thought Soup
              hell, i'll take the 1 hour /1hr 15min one even....better than the other options, imo. I also emailed Mini-box to see if i can get an answer from them.
                Andrei from Mini-Box confirmed the existance of the
                settings via e-mail. He also said that the source code for the unit is available for modification. I wonder what sort of work it would be to modify the code...
                Source code in zip file is available here:
                http://www.epiacenter.com/modules.ph...rticle&sid=529
                  They reference using the "PicStart Plus" to program the PIC - a bargain at $199. Uh, no thanks, I think I'll just stick with what's pre-programmed! I know less than nothing about PICs though, maybe there's a better way (ie cheaper).
                  540i / 320i Mods
                  iPhone Hacks
                  Thought Soup
                    Thanks Darthtater, that is exactly what I was looking for. And you're right about the DSATX as well, great powersupply but overflows its place in the budget somewhat. I think either of these should be in the documentation,
                    They seem more useful than the ones already there.
                      I jumped the gun a bit. Here's a kit that's pretty cheap if you're able to solder. They have it assembled as well, but it adds a lot to the price.
                      http://electronickits.com/kit/complete/prog/ck1700.htm
                      540i / 320i Mods
                      iPhone Hacks
                      Thought Soup
                        whats SureStop when its at home??
                        Visit my site V8 Scimitar
                        SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
                          I think SureStop is the configuration where the M2-ATX never sends a start pulse to the mainboard. It will shut the mainboard down, but you have to start it manually.
                            what about:
                            0011
                            1011
                            0111
                            1111
                            are those jumper settings not supported, or just not documented?
                              Originally posted by alpha_maverick
                              what about:
                              0011
                              1011
                              0111
                              1111
                              Well, they aren't listed in the user manual, nor was i informed of those settings when i contacted the manufacturer, so i'm assuming that there isnt' any modes that are associated with those configurations.....but i'm don't know for sure. I would think that the guy that emailed me with the previous information would have told me about those too if they did anything.
