Need: Startup/Shutdown Controller Suggestion for Morex PSU
  • Need: Startup/Shutdown Controller Suggestion for Morex PSU
    Ok, I have a Nehemiah M-10000 cpu/motherboard setup with a Morex 3688 case w/ 60W PSU.
    I'd ideally like to run my screen off the PSU in the case as well as add a startup/shutdown controller.
    Q#1: Do I need a higher wattage PSU to power the screen as well? (it's a 12v lcd)
    Q#2: Will an M1 or M2 PSU fit in a Morex case to replace the 60w psu.
    Q#3: What is the most ideal situation for powering this all?
    I was looking at these options:
    Morex 80W Car Kit
    http://www.logicsupply.com/product_i...roducts_id/228
    M1 ATX PSU
    http://www.logicsupply.com/product_i...roducts_id/285
    Micro Shutdown Controller
    http://www.mp3car.com/store/product_...products_id=58
    Syprus Design Technologies - CarPC Project (Sold)
    ok, it's hard for me to believe no one has any idea what i'm talking about...
    after no responses i decided upon the M1 ATX
    I'll use an amp install kit to connect it to the car battery, and use a molex connector spliced into the LCD power cable to power the LCD from the M1 ATX
      Search for Carnetix on this site or go to carnetix website. They have a regulator (with SDC function built-in) build for the Morex case.
      Y2K Accord Dell GX150
      EmoRebellion is a SCAMMER
        Why do you need a shutdown controller if the M1 already has one?
        Also be careful not to overload the M1, i'm going to wire my LCD to the cigarette lighter wire.
          1 - This thread is nearly a year and a half old.
          2 - He made the M1ATX decision after nobody responded to his question about the SDC.
          I'm reasonably certain that if this was an issue, we would ha ve heard about it from this member already.
          How about the Wiki?
            Thanks for the response, i didnt realize this thread was that old.
            How can I wire a lilliput to the M1 PSU? Just splice it in somewhere?
