It never fails
  • It never fails
    Does everyone else always have to buy 2 of whatever Mini-box makes inoder to get one that works? I had to buy 2 ITPS's to get one that worked. Sadly I'm in the same boat with the M2-ATX. The AMP remote on lead puts out about 4 volts, nowhere close to enough to trigger a relay or an amp to turn on. So I do have one of the working M2's that will boot a M10000 with no problems however I've yet to find a way to trigger my amp. So I ran another relay off the 12 volt feed from the PS to trigger the amp. I have turn off pop but not turn on pops. Sadly for $95 I thought it would work better than it is. I'll look for a cold solder at some point but doubt that's the cause.
    2K SVT Lightning, Some things and the usual truck pc, now with slot load dvd rom and ECM Data logging.
    05 Scion xA
    Don't you return the one that doesn't work for replacement?
    Or are you buying from a private seller where there's no warranty?
    How about the Wiki?
      I do return it. It just ****es me off that I give a said store $100 for parts. Rush order, Priority handling yada ya. To get it nearly 3 weeks later. Then have to send it back for RMA, another 3 weeks. so for a month and a half I've paid for something that doesn't work, so I get clipped on the warranty and the use for a good amount of time. And so far it's only be with every mini-box product I've delt with.
      BTW nice quote. I love the Report.
      05 Scion xA
