Can somebody identify this PSU?
  • Can somebody identify this PSU?
    I have a power supply that came in a small case with an EVEm motherboard.
    I am trying to find the specs for it.
    Here is everything written on the PSU:
    EVEM_DCDC
    REV:1.0A
    E206922 PS-1
    888
    020228
    The motherboard is an EVEm Mini MicroATX
    Any help would be greatly appreciated.
    Anyone? Anyone?
      a picture would help
      PC Components:
      My work log
        I have that PSU. mine is Rev. 1.0B though.
        It came with my U-Buddie system. VIA C3, Samuel-2 core. Don't know how much it's rated for, but I used a 60W AC-DC power brick for it.
        RED 1999 ACURA INTEGRA GSR STOLEN -- CHICAGO 02/27/08
        VIN JH4DC2391XS002416
        PLATE ILLINOIS 5287412
        Team Integra Markings on Rear Quarterpanel Windows
        REPORT TO 911 IF FOUND
          Here is a pic of that power supply. I am trying to find out the output rating, and also how big of a dropping resistor I should put on the input side to keep from frying it.
          Any help would be greatly appreciated!
            So I should be able to wire this unit directly to the 12V in my car and be safe?
            Does anyone know what the jumper on the unit is for?
            This PSU came with my P6VEM3 MB which I am just getting ready to mount in my car.
            Thanks!
              Doubt it'll survive crank, but you should be able to.
                OK, so do you have anything useful to contribute to the question?
                  As stated, it should be able to run off your car's 12V, but it will not survive crank. Every other question I have no answer to. Cheers.
                    So what is that supposed to mean?
                      It means exactly what he said, which answers your question.
                      I, however, disagree. I wouldn't recommend connecting that PSU directly to the vehicle's 12v electrical system. I would recommend feeding it regulated 12v DC power.
                      I'm missing what information you're fishing for....
                      Perhaps if you ask a specific question, you'll get a specific answer....
                      How about the Wiki?
                        So if I crank the car it will explode the power supply or something?
                          It'll most likely trip the undervoltage protection of the voltage regulator and MCUs of the PSU and turn itself off.
                            YEah, that's it.
                            You really need to do some reading on these forums a bit.
                            There are more discussions about surviving crank than you can throw a stick at.
                            How about the Wiki?
                              I have one of these as well in side a case in my bits box but dont have a power brick for it i take it that that is 60 w at 12 v and which way round is the center of the jack 12v or the out side if you don't mind me asking
