  • Outputs
    I am looking at power supplys and I have started wondering what out puts they have. I was looking at both the opus and the carnetix dual output. I want to know what connectors they have. It says you can change what the output voltage is on each one but what does the connector look like?
    I want to connect a Motherboard, dvd drive, and Hard drive, along with a few other things. I was looking at this and wondering if it says dual output that means it has only two outputs! I want to connect at least 3-5 things.
    Another problem is I have two cigerate lighters and I was planing on cutting on off and connecting the power supply to that. Would that work? I am almost done with my planing and I want to start fabbing. This is the last problem/question with my set up.
    You know you're an engineer if you have no life & can prove it mathematically.
